ammar.cma
Advice For Buying A New Phone For My Sister
Hello Rimwebians,
My sister sends a daily texts normally 300-400 ,
therefore
I need a good phone which has a robust qwerty and dual sim is necessary
GSM + GSM
Sound quality should be good and it should be 3.5mm jack..
If anyone has any offers on the forum too...please guide me through..
Thanks!
Budget ?
As per new TRAI guideline.you won't be able to send more than 100 SMS per day..So for 300 msgs.you will require a triple Sim cellphone.
hi,
For dual sim and qwerty, you can see many micromax handset but its not worth buying.
for querty and dual sim i would suggest samsung chat, motorolla ex119. If see can compromise the querty and see can also go for spice m-6900
or one of the best option is nokia c2-03 touch and type. This one highly recommended.
btw all the phone is in range of 3k to 5k.
Edited by sunilromy
Budget is under 6 or 7k! ..i was talking abt old times ....300-400 msgs....though she sends all of that 100 msgs! :P
I will not recommend samsung from my experience if she is such a frequent messager like me.. Samsung dual sim phones get very slow after storage of 100msgs.. IMO go for nokia C2-03 although this is not qwerty. Dont go for chinese craps.
