alibawa9211
Total Call Duration on Palm Pixi
Currently I purchased palm pixi from ebay. Working good. No problem at all in functions but to know how to view total call duration. Call duration is visible in current call and that's fine. But I cant find how much I talked by this phone in total. please help...
There is a small bug in Sprint call duration option. but if you are using verizon pixi plus it should work normally.
here is work around or u can call it patch
  • Install WebOS Quick Install if you have not done so already (I won't go into it, as most people here already have it going. For those that don't, http://forums.precentral.net/canuck-...ml#post2194980).
  • Make sure your phone has Developer Mode enabled (see link above for how) and connect it up. Tap "Just Charge".
  • On WebOS QI, click Tools --> Linux Commandline.
  • At the prompt, type the following:
    luna-send -n 1 palm://com.palm.systemservice/setPreferences '{"phoneAppHideCallDuration":false}'
    pkill LunaSysMgr[/CODE]
  • This will change the flag in the Palm database and restart Luna.
  • Check your call log. Durations!!! If some of your call history is "missing", just restart Luna again (pkill LunaSysMgr) and they should return.
  • Disconnect your phone, and disable Dev Mode, if you so choose.
welcome back hitesh bhai... :)
