jainoffice
Lg Rd 2030 (rconnect Problem)
I am facing following problem while connecting to R connect.
I have to adjust the data cable in a particular angle to connect to internet.
Sometime it wroks and most of the time it does not. It gives the error 'Hardware Failure'
And once it is connect and if I the cable is moved the internet connection is disconnected
My question is where the fault is? Is the cable need to be replaced or Phone is dying ?
Please Help
Yogesh
Most probabily Cable problem!!!
Try 2 things!
1.) Check another cable with ur phone.
2.) Check other phone with ur cable.
U'll be able to know whats the cause of problem...
