rajeshkatiyar
R Connect By Lg Rd 2530
Dear friends
Recently my brother in law found a interesting thing
He put his LG 5340 lead to Lg 2530 life long set.
According to company 2530 is not data
enabled . but dail up connection accepted and R connect
was estabilished. i think it has a modem
regards
Oh yes Simply install LG Rconnect software by CD
Also the data lead is same of 5340 . In fact my
brother in law experimented . I am waiting others
opinion regarding it
even 2340 also works.
Will You Please give me step by step installatation process so i can connect or for which mobile software u installed for it???? are u installing 5340 driver for mobile or 2530 ??
even lg 2670 has internet
Please give detailed informations like which type of cable tried and software used. It will help more.
Just simple one line informations can't help.
Please Please do it....
Yes.....
I also experienced with 2530 with LG 2230 and its works. As per my knowledge all reliance LG models come with R connect / internet facility.
Just purchase the DATA Cable for your LG 2530. As their is no facility of data transfer in 2530 hence you will not get the data cable for LG 2530 hence you need to purchase the suitable DATA Cable (like LG 2230) which will work and fit in 2530.
Install the driver / software come with that Data Cable.
User ID : your mobile No.
Password : your mobile No.
and phone # #777 (In Ahmedabad) (I believe its same in all India)
and try to connect it
However, I cannot sure about the speed. I am getting 153KB speed.
Check it out
Question: email 'davidforyou@gmail.com'
P.S. : Please do it on your risk. but I am sure it will work
Edited by davidforyou
