Himanshu Singh
Which One Is Better Between Lg 3510 And 3530?
Please suggest. I need to buy a phone by tomorrow.
Both hand set specs are same,
you have to go on looks,
which is personal choice. so which ever looks good to you, go 4 it.
Hitesh Bhai is absoultly right,100% same from in side.go on the look only.
Lookswise 3530 seems better.I am going to take it.Thanks.
Got LG 3530 for 870.
available in pune for 830 from direct dealer
