Himanshu Singh
Please Suggest Me A Tata Postpaid Plan
Hello Friends.. I have a Delhi prepaid tata connection which I am planning to convert into postpaid only for roaming purposes.. I want to have the following benefits:
1. minimum 1000 mins free incoming
2. Tata to tata free or very cheap
3. Free national roaming sms or very cheap sms.
Is there any such plan with Tata in Delhi? Or is there some combination of value packs available? Hope friends using Tata would enlighten me..
Best way possible is to visit the HUB, they will suggest a plan according to your need.
I have sms pack but it is not available for new customers as of now.
Dear Friend, go for CallIndiaRoam399 plan.. I am also using this plan.. Also add LocalT2T pack for Rs99 for FREE Unlimited Tata to Tata (Incl virgin CDMA <<I hope NO DOCOMO or VirginGSM in Delhi>> )...
For Rs399+Rs99 you get following:-
0) Rs300/- FREE USAGE in Home circle..
1) You get 2000 FREE Incoming calls in Roaming..
2) T2T FREE in HomeCircle (NOT in Roaming)
3) 399 Local/National SMS FREE also in Roaming (without a pack) :clap:
4) Locals @ 30p/min, STD @ 50p/min in Home
5) ALL Roaming outgoing @ 50p/min...
This is the best roaming plan.. This plan is also available in Delhi.. You can go for it...
UPDATE:-
But the best ROAMING plan in India is available in RoTN now and see here for details :winko:
Edited by KanagaDeepan
