goluman
How to know if BlackBerry is Unlocked or not?
I have procured a BB8330 from Sadik, In the operator screen it shows an operator called FAST 100 and My number -5129*****8, same is reflected in Mobile Directory number and IMSI_S number.
Tata Indicom people told me that they can register ESN if the phone is unlocked ,not locked to any network or if unlock code is available.is the unlock code for BB8330 the SPC code or something else?
I have Loaded tata prl etc successfully but network operator does not change ,Shows FAST 100 only.However in the SPC details all information like county code,network code etc are programmed for Tata Indicom only.
Please help me!
Dial *228 on phone and check what it says, if it says :- Welcome to Reliance then its connected to reliance , this can happen if phone is in roaming .
if it says Thank you for choosing our network, and then press 1 forĀ  pre paid or 2 for post paid that means its connecting to TATA
also as you know your SPC that means phone is unlocked for network programing.
^^ Hitesh Simply Great answer,
