ashwani_0501
Contact Numbers Not Displaying on Incoming Calls in BlackBerry 8830
Hi to all,
I am facing a strange problem in my Sprint 8830:
While using Reliance CDMA no. I can get caller names from address book on incoming calls, but when I switch to Reliance GSM, incoming calls doesn't show any caller names.
I have tried following:
1) Disabling content protection.
2) Changed country code/Area code in Smart Dialing, but nothing helped me out.
please advise any solution to come out from this problem..
:signthankspin:
Can you share how you solved it?
My Pleasure to share the solution.. :Chulo:
What I have done earlier is, I have synced my address book from outlook contacts where I have saved contact nos. with '0' zero as prefix
In smart dialing option I have put country code +91 which may caused the conflict.
I have just removed prefixed zero from saved contacts & got the problem solved, now my incoming calls associated with address book contacts shows the name of caller. :SI:
