ananth001
Cannot Mount SD card in Storage Mode on Samsung Epic 4G
hi all
i'm not able to mount sd card in mass storage mode to copy files from / to between card and pc. do I need to first format the sd card
Dial ##upst# & post what option you get?
thanks Sumeet and Kalpak ji. Just had to put phone in PDA mode dialing ##8778#. Now I can mount it
Enjoy :-)
elementary dr. watson...
Dont we get option after plug and play like HTC? I think we do get when epic was in my hands for few days.
it was basically in diag mode in htc's language....
rightly said dhiraj bhai. really stupid of me to have posted this without doing basic research
It happens as in epic option of usb connection goes away when diag mode is made permanently ON.
I can't connect my EPIC using MASS STORAGE mode, even if I select the MASS-STORAGE option while connecting it to USB, I dont see the Drive in my computer... I have installed drivers, tried with enabling and disabling the USB-Debugging mode... But nothing works...
For transfering small files, I send the file to my gmail account and for larger video files, I am using card-reader... Please help me in getting USB-Mass Storage mode
On putting ##8778# shows 1) Modem and 2) Modem selected and PDA being NOT selected in two places.... Please help Gurus...
Edited by KanagaDeepan
In UART - Select - Modem
In USB - Select - PDA
then it will work.........
Sellers forgetting to put back to PDA mode more frequently now i suppose - must me worried about A-Key
