androidhelp
Tata Photon Plus And Android Tablet
I bought a cheap Wespro Android Tablet from naaptol.com thinking as it has usb port, would run tata photon plus.
But after buying it i found it was not possible.
1 )I wanted to know was it due to it's Android 1.9 os or tablet don't ever support photon plus.
2) I also read somewhere that tablet os can be changed but don't understand how ??
3) Will changing os from ANDROID 1.9 to WINDOW CE help me run photon plus ??
4) What is firmware ??
image :
Dude, these tabs are wifi, and it is easier to now buy a 3g to wifi router than use data card directly with it. else if you have an android phone , you can make it a hotspot and use it.
I have one oh the tabs and i use my one netconnect for me 2 lappies, the tablet n my phones..... :clap:
Edited by rohitgaur
I am using tataphoton+ Usb modem on Leoxsys wifi router to connect my Galaxy Tab.
