abhi gaurav
Issue After Upgrading To 2.3.3 Of My Droid X
Hi to all gurus and all rimwebians..
I am facing many problems after upgrading my droid x to 2.3.3 and first time i am really feeling that sometime these android phones really su**s(sorry if i am being so rough)but i am writing what i am feeling..
these are the information regarding my phone:
System version 4.5.596.MB810
Android Version 2.3.3
Build number : 4.5.1_57_DX5-26
After upgrading it i am facing following issue:
1.Every time it is switching on by itself ,if i am switching it off(just imagine i am on a tour and i am switching it off to save the battery)
2.When i am taking the photos sometimes it is getting saved and sometimes it is not(think what my all frds would have saying regarding use of its 8 MP camera)
3.when i am listening the music through earphone ,its sound is so bad that i can't explain (i can't say that why this problem has occured but prior to upgraded it was not there,even when i used nokia 3.5 mm headphone then all there fast forward and play -pause buttons were not even working)
4.I am not able to download any application from market
Now just imagine how i am feeling when all my frds are saying that why did u spend 30k nd why u r using this phone ,juss simply throw it.
So Gurus plz help me...Izzat ka sawal hain ...
1. contact ur seller from whom u purchased this set
2. did u try doing a factory reset after upgrade to solve your issue? sometimes clearing cache solves this
thanks for the reply sir.I have done cleared cache but that is not solving.Factory reset i have not done,since i am outside my hometown so i have a fear that anything goes wrong to bachi khuchi izzat bhi jayegi.I have bought this from Hetal sir ,so i will contact him as soon as i will reach to kolkata.
izzat bachne ka simple solution...
blame it all on reliance :D
i do all the time.
tell people my handset is uber, but reliance is not . :lol:
sometimes i feel gsm is lot simpler... just change of sim card... but still i stick with reliance :) because of cheap voice call plans on roaming
@Gaurav
Have you rooted and installed recovery when you where on 2.2 ?
Also nand backup ?
if you have your nand backup, just restore it and go back to 2.2
@ D kaile,,thx sirji ..after factory reset now i am able to download apps from market and seems that saving of photo issue has also been solved..but suggest me one thing that should i restore the app using titanium back up or any other software which don't restore system data.
Music is still an issue it suddenly stops by itself when i am listening songs.
@ abhishek..really sometimes i also blame on reliance...especially when i am roaming they simply debar my outgoing call and say me to contact to webworld and again after someime they start t by their own..
@ hitesh ..no sirji i dont have the nand backup of 2.2...
