dkaile
Review: Sprint Samsung Galaxy Note II - SPH-L900 - The Next Big Thing
I know it's your friends, you were just checking.
Posted Image
Changed the first three entries to 0.0.0.0 and 0 and 0 respectively, still not able to get youtube tobl work over 3G
Sent from my SPH-L900 using Tapatalk 2
Mmsc proxy must be 0.0.0.0 as its IP address
Sent from my SCH-R950 using Tapatalk
^ I guess the first three are related to MMS and not to multimedia. Check my next post for screenshot.
Sirji, this is all i get. I am on 4.1.2 Mc2
Even Facebook videos are not playing,what do I do?
I was having the same issue on 4.1.2 (a few posts above). Updated to 4.3 and the multimedia option appeared on that menu.
Yeah now updated to 4.3 but still there is lag on it! I felt lag on both mc2 and mk4! Duno why!!
I have a slight issue (more of an annoyance) using the Sprint GN 2: When dialing any number in international dialing format (with +91 prefix) I get a message "Please check the number you have dialed" and the number is not connected. But when i remove the +91 prefix the numbers connect without any problem.
Any fix for this - its kinda annoying since I share my phonebook (Google) among 2 phones (ip5 & GN2) and all the numbers are saved in international format...
If your GN2 is CDMA, it wont take +91. You need to change it to 0091
I guess 0091 will work in GSM too
Use Number fixer to update phonebook
https://play.google.com/store/apps/details?id=com.maplekeycompany.apps.numberfixer
Yes sir! It (the Note 2 is on Reliance CDMA indeed). Thanks so much for the information and tip on how to fix it.
@ankitdaluka: Thank you too for the app tip, shall try it out and ping you if having any difficulty.
Edited by puneet_si
Also, sometimes what happens is that you receive calls from number starting with +91 which is not saved in your contact list. So when you need to call that number, you will need to remove manually the "+91" part.
Rather, use Software available for free in Play Store called "Prefixer" and set appropriate rules.
After this, what will happen is that whenever u dial a number starting with "+91", it will automatically remove "+91" and replace it with "0".
If u have any difficulty in making rules, PM me.
I am getting notification for upgrade of 4.3. Should i upgrade? Is it change reliance settings and need to flash again?
Go a head, as roll back is available
wont brake reliance settings
tapatalking....
Edited by ::Hitesh::
Whats this? Any idea? I have only one gb limit and Google services has used up 208 mb already. Anyone can help me stop it? I clicked on restrict background data usage.
look for google bookmark, contact sync , play services etc...
they are using this data, go to their settings and block background data.
looks like you have newly added gmail account.
Only google contact and mail sync is on.
4.4 source code released. Can expect a working rom by 3-4 days.
Updated to KitKat (4.4.2) using a stock-ish custom ROM from XDA, running fine so far (data and hotspot working out of the box).
post-4034-0-13155900-1403264386_thumb.pn
Also wondering if anyone has an idea about which baseband/modem version works best with Reliance CDMA in India for best reception (ranging from LJ1 to NE2)?
Edited by puneet_si
Have finally moved over to the Dark Side (GSM) and modified my Sprint Note 2 to GSM (using Verizon Note 2's sim tray and midframe, accompanied by carrier unlock). Seems to be working fine so far.
Quite interesting
