Go take OTA from zv8 to zvA, everything goes normal until phone stared first time..
Screen was displaying Com. Android . phone has stopped continuously.. I was not able to even unlock the screen that fast that error was coming each time.. So perform hard reset and clear cache and everything come back to normal..
Root is there, unlock is working and Hotspot is working to..
The biggest difference I found between update is when we turn on data, on ZV8 for 3G network "h+"symbol coming and for 2G "E"..
But now on for 3G and 2G I am seeing symbol "GSM"..
Any way to get back to normal symbol..
Sent from my XT907 using Tapatalk
Which baseband are you on now? ZVA? Or 8
Sent from my LG-LS980 using Tapatalk
Right now I am on ZVA... And that symbol change on ZVA..
Symbol was normal on ZV8 application and now it has shown as picture...
You can't change it as the icons are upgraded in ZVA. Let it be. ZVA modem is slower compared with the ZV7/8
ZVA is a update, I guess you are asking the other way. ZVA to ZV8. Yeah you can, just use the flash tool and flash the tot.
One can only update from ZV8 to ZVA.
Manoj Patel, did you fix the problem: com .Android .phone?
Do you have the same problem?
I has that problem too, i have a solution too.
Do a factory reset, but don't do the normal way.
1- turn off your phone
2- enter to recovery (power + vol- until the mode recovery is activated)
3- do wipe in both option, first in factory reset and then in cache.
The phone will reboot.
I do that and my problem gone
Thanks for sharing this information. This will help a lot of people. Will update the same in OP. Thanks one again.
Got it working on same day, by using recovery same way mention by you few post above..
unlocked gsm on zva but cant replace apns-conf.xml,
what to do
Install hiapn from play store
It will auto set apn based on sim
Sent from my VS980 4G using Tapatalk
Hey everyone. I am so confused and hope I did not screw anything up. I am rooted. I have total commander running. When I find my device, and go into the carrier folder, I attempt to right click the property folder and then click copy. When I do, a box pops up that says "download to" then I have the option to click OK, TREE, or Cancel. I typed carrier in the box, and root manager on the device made me accept it, but then nothing happened. I cant help but feel I am doing something wrong. I have been trying to understand this for hours and I am just stuck and stumped. I don't know where to go from here or what I am doing wrong
F5 to copy from one side to other F8 to delete, do not use right click.
Downgrade zvc to zv7? Vinod Nayak
Hello Friend
Need some help before i proceed with the unlock you provided
On a LG G2 LG-LS980
i am currently rooted running cyanogenMod
Baseband M897A-AAAANAZM-1.0.190034
Please can you help me with procedure to downgrade my baseband for the unlock you provided to work
Also, is there a different procedure i could use without downgrading?
thx
Cm11 should be unlocked default.
hello Friend
are u referring to my below post
Hello Friend
On a LG G2 LG-LS980
thx
CM file system is different from stock. I am not sure if this unlock cab be done with cm11, I have seen people from xda post about GSM being unlocked on CM. Regarding downgrading your search of LG G2 unbrick unroot in this site. It has all the information you need.
Hello Bud,
Please can you provide a link or details on how to do this while running cyanogenMod
thx
Can this unlocked work if we use 4.4. tot file provided by autoprime and flash it through Lg flash tool...
Can we still able to unlock..?
Yes
