Nilesh Deshpande
Help Setting Up Rconnect With Nokia 6235
Hi All,
I just bought a Nokia 6235 and DKU-2 Data cable.
I tried downloading from the Reliance website the rconnect dialer and the drivers.
But the dialer is not there in the zip file available for downloads.
So i have now installed the modem and set up a new dial up connection to #777
When I dial this connection, the message comes on the phone calling #777 and then "call ended."
How do I get connected with my 6235? Any tips?
I am using win2000 at office and win xp pro at home.
Thanks a lot.
Nilesh
Are you sure the phone is not in lock mode ? Have you unlocked the phone by entering the secret code, before dialling ?
Hi
Use DKU-5 cable. I have connected using DKU-5 instead of DKU-2.
Ajit Kushwaha
Hi All,
Thanks a lot.
Nilesh
Well go in control panel then Phone and Modems options then click on Modems and see whether the Nokia modem is instaled or not.If it is installed then highlight it and click on Properties and then click on Advanced and then enter " at+crm=1+cso=33 ".Then try connecting. :clap:
Well go in control panel then Phone and Modems options then click on Modems and see whether the Nokia modem is instaled or not.If it is installed then highlight it and click on Properties and then click on Advanced and then enter " at+crm=1+cso=33 ".Then try connecting. :angry:
Nilesh did u got connected ?????
Please tell us..
