rk19801
2112 Problem
when i try to use browser my phone go hang no go back menu or not open page its 2112 using with tata in mumbai so pls help me what is actually problem pls help me for that & also help me how to use browser in 2112
press the on off button for a while after opening the browser and you will get the mini browser menu,using this u can reload the page if this does not work then use advance option and restart minibrowser,this should solve your problem.
you can also try changing your home page
THANKS FRIEND I WILL TRY IT & CONFORM WITH U THANKS AGAIN
THANKS I TRY IT IT DEFINETLY WORK
THANKS ONCE AGAIN
you are most welcome my friend :Equivocado:
