sanblr
Connecting normal phone to FWP
No. You cannot. You can only connect a data cable.
Thanks :quest:
anyone knows about CELL SOCKET .....
is anything for CDMA CELL SOCKET :quest::quest:
I have a similar Problem.
First, I own an FWP and want to Attach it on Billing Machine of My PCO. So I need something like a CELL SOCKET.
I got all my creativity out and have comeup with a solution.
I have got a box made which throws a Dialtone and manages the Off Hook and On Hook Current this Box Detects the DTMF and send it to my Computer.
I have the Audio of my FWP connected to the BOX and hence they both are talking.
All I am not able to do now is make the bloody FWP dial the Digits from my Software.
My Software sends ATDTxxxx command to the Phone and It works perfectly, But for some reasons it disconnects immediately and says that its not a Data Call.
Can Someone give me how to make Normal Phone Calls out of the FWP. Maybe an Equivalent of ATDT or some mode setting.
Regards,
PCOGuy
Why don't you go for a FWT? Where you can connect them to cell socket.
Moreover Reliance is now offering FWT'S free for PCO'S and you get a handsome comission with them.
FWT it seems are out of stock or non-distributed.
I went to OTC & WW twice and I was told that FWTs wont be issued.
Secondly, the pleasure of paying later and using now is lil different than the PrePay stuff.
Moreover, RIM is still not officially declared anything on the Prepaid PCO and Prepay FWT etc..
And I am a geek with my soda glasses who is sitting in the PCO the whole day and managing "CHUTTA".. and I WANT TO DO THIS.
GUYS..... ;) I found the AT COMMANDS....
MY FWP Dials a Voice Call on AT+CDVxxxxx Perfectly.
No I want a OffHook On Hook Status of my FWP. Any Clues..
Looks like my stuff will work. :D
Regards,
PCOGuy
