nupats
Signal Booster For Lg Cdma Mobile
hi guys, i have a LG 6130. I work from a basement office in Colaba and signal strength is "zilch". I need to come upstairs to the coffee room for making calls.
any idea about the signal boosters available..
urgent please...!!!
reg
nupats
there are booster available for cdma mobile phones for around rs.500-600
Can you please tell me where it is available ?
I mean is it available in LG Service Center ?
hi suviraj
really want one asap. Could you pin point the location where i can pick one ?
i cant pin point the shop as such..but its available in mumbai at lamington road....the same type of antennas are provided for pco coin phones by some operators..if you have noticed some where///
Edited by suvirajshetty
@suviraj
My dear friend, actually you are referring to PPA (Patch Panel Antenna). These PPA works with ony FWP and FWT only and can not be used with mobiles.
You can get an external Antenna. which look like our old TV antenna. It cost me around 2.5K around 5 years back. I was using it my Alcatel mobile in my village in kerala. No I dont use it as now I have tower in our village. It will catch signal from around 12 KM.
Not such antennas are practical to use.
U just make strong complain to reliance thy will do something for u.
Our forum member Kshah made them stand one whole tower in his area. way to go.
