ash1005
Power Consumption Question
I want to know two things
1.Doing internet through edge enabled nokia(any gsm)handset by bluetooth consumes more power(battery) than usb data cable?
2.Will doing internet on regular basic with this edge enabled nokia handset costs its battery life or hardware in any way? Thanks
1) Obviously bluetooth will consume more power
2) It will have a toll on the battery life eventually, but that will happen as a battery won't last forever and will have an end-of-life after long usage. It shouldn't cause any issues in the hardware though.
yes no issues to the hardware ..
but using edge will consume a lot of battery power ..
your battery will get depleted in a day if u browse for 1-2 hrs
Then can i see this edge enabled phone for pc browsing when the battery is charging from wall socket since i can recharge the battery as well as connect the phone to pc simultaneously(it has got two distinct socket one for charging other to connect the data cable)
Would it affect the phone?
no it wudnt affect the phone but ur phone will surely get heated up in doing this...
