zeus
R-connect Bill
hi everybody
I had a lil confusion regarding the bill for my LSP-340e phone which i took under the 500 scheme .
Haven't got any bill from reliance yet & thats a big surprise coz i started using this phone for internet since May ...
now one of my friends told me to check the bill by dialing *366 . & what I find -->
* your unbilled amount as on 17 Sep is Rs 1521 & 20 paise ..... *
Does this mean i have only used internet worth Rs 1521 ? ;)
If yes , wow thats a rip-off then . coz I regularily consume 90 hrs of net / month . and that means 90 X 4 = 360 hrs (may,jun,jul,aug)
=> 360 X 12 = Rs 4320 atleast ..
or am i missing something here .
plz help ...
It doesnt includes data charges, it is only for call charges.
is that true ?
But then how can the bill be so much coz i haven't made a single phone call from this phone yet ..
getting more confused now
No greens
I also have FWP.
And the bill contains both call charges as well as data charges in 500.
I mean if u didnt make any call but did net so data charges will be included in 500.
and zeus
U can check ur bill at Reliance web site.
It has detailed information.
http://bill.relianceinfo.com/webapp/portal...et/LoginServlet
thanks bro for clearing that up ... checked that website too & its also showing the same amount ..
hehe , maybe a bug has saved me from a lot of money :rolleyes:
Unbilled usage only contains call charges. However when you use R-Connect, everytime you log on you are charged a call in addition to the data usage charges. This is what you are seeing in the unbilled usage.
hey isacoyd that's not true.
I've a FWP connection.
and every month i get my FWP bill as it is told by Unbilled info.
and i also use R-Connect 1 or 2 hours daily.
so ur FWP unbilled info tells ur total bill for call charges as well as data charges.
Ah .. the confusion was getting big me on me , so i went to check it out with their officials . and yes Vishal is correct , the unbilled amount is the total amount I'd have to pay ..
which means Rs 1521 for 4 months of usage .. haha thats a ripper :rolleyes:
Very strange!!!
I wonder how is it possible?
definitely another bug in their billing S/W.
GOOD to see.
Hehe dont worry.. Reliance dont give u such surprises alone..
Check ur next months bill, it might get something extra in it :P
da dreaded thing has happened bro .. jus recieved a shocker 4m reliance , they say i hv to pay 16000 bucks for 4 months of usage .. thas crazy considering that my unbilled amount was jus 1550 somethin a couple of days ago ...
Guys ...thats the problem ...customers should in general never get into plans with ambiguities! The RIM R-connect plans are devoid of any transparency and everybody should shun them until and unless RIM does something about it! :D
I'm glad I decided not to go for it...
RConnect is a new tool for Reliance to charge inflated bills.......................!
Hey zeus!
U told that:
So tell me when u used those hours?
I mean in before 10:30 pm or after 10:30 pm.
If before, then u'll charged according to 26 Rs. per hour.
So ur bill might be right.
Cauz u expand so much hours on net.
Hey zeus!
U told that:
14494[/snapback]
na man , thas not da case i fink coz 95 % of the time , i surf at night or on Sundays ..
I mean , even if u take 26 bucks an hour , da bill should be 360 x 26 = 9360 ..
I think this is another bug in their system , coz it has happened with a couple of my friends too ..
