Vishal Gupta
R-connect Dialer From Reliance
Hi guys!
RConnect Dialer provided by Reliance doesnt work properly.
I mean there r two Check Boxes in this dialer:
Save Password
Launch IE
In older versions these were not present.
Now come to the problem.
These check boxes dont remember their settings.
Save Password by default is not selected and Launch IE is selected.
But if i unselect Launch IE check box, it works. But after exiting Dialer if i reopen dialer, it forgets the setting and Launch IE is selected again.
Same for Save Password.
Very irritating!
Does anyone know the solution?
Hey vishal, the save password works.ignore what you see in the password feild when u open the dialer and click connect.even though it shows absurd passwords there, it will connect.dont ask me how ;)
yup...id does connect...even if i UNcheck the "remember password", the dialer remembers some 16 digit password with which it connects successfuly!!
may be.
But it always open IE windows, even i unchecked the checkbox "Launch IE".
Other wise create a shortcut for Rconnect dialer from network and dial up connection, that will solve all these problems.
Yes the dialer is worst programming.... i make shortcut for rconnect dial up connection and i am using only that.
16196[/snapback]
Huh? :)
Whats is this supposed to mean ?
Is there a universal, hard coded password ?
No, its windows XP feature.
I think rEdshiFt is using win XP.
In win 98 password is shown of the actual length.
But in XP it shows many stars instead of the actual length.
