Saurav
Charging While Surfing
The USB data cable provided with handset does not support charging while using RCONNECT.
Is it possible to charge GTran while using RConnect.
I saw my friend's USB cable of LG RD2030 charges the phone during R-Connect.
It was local not provided by Reliance.
4 gtran local cables are not available.
change your phone to lg then
17781[/snapback]
Can't you use the desktop charger ?
If not then as you replied yourself that no third party cables are available for gtran. So it is not be possible.
we must try to find solution. try try again
Edited by Saurav
Thanks Saurav for this Post. I have a peculiar experience to share on this topic. May be we can say this a bug :rolleyes:
I always keep the H/S on the desktop charger so that when I log off the set retains enough power to talk with. One strange thing happens though. When the charger shows Green Light the H/S stops receiving calories from it :clap: If I disconnect the Charger from the plug and reconnect the h/s starts charging again but the RConnects gets disconnected immediately <_<
Advut Na?
Edited by Utsav
