MGR
How To Connect Internet Through Lg RD 3150 Mobile?
I have purchased LG RD3510 handset recently & also purchased data cable from outside. & also installed lg desktop & modem driver. I want to know how to connect internet using Mobile as modem. Pls provide me complete procedures.
This phone doesnt have an inbuilt modem
SO netconnect not possible
@Ramprasad
PC Sync tool will work fine,
But as there is no modem in the phone how did you installed modem driver for it ?? :confuse: :confuse: :confuse:
As above two post said, i am saying same thing not possible on your handset..
Edited by hitesh123
I have downloaded PCSYNC software & modem driver from http://lgmobiles.com/index_cdma.php & http://www.lgmobiles.com/PCsync/RD3500_Sync_Setup.zip & installed. after installing that software my pc is showing modem when i connect the handset to PC
^ can you pls. take a screenshot & attach it for better resolution of your issue.. Also check your Device Manager for the installed Communication Devices after attaching the phone..
Edited by ak9888
PFA screenshot
same with LG 3500 and others but it does not have any AT commands in its BIN. dont waste time
yup!! u r right , but is there any possibility of any sort of programing !!!!
