KapilAgrawal
Flash & Recovery Solutions For HTC Incredible 2
Kapilbhai, how to s-off Incredible 2 with H.Boot 0.98
Resolved your query.
Kapil,
Can u pls. share the link for the ROM's as the earlier Megaupload links are dead due to megaupload issues..
Thanks..
Hi gurus,
I am currently using 1.09.01.022 radio with reliance. updating my radio to new version (verizon) can cause any problems to reliance connection? (calling and data). pls share your thoughts
Kapil Bhai Same here ,
pl help how to do S-OFF , iam with HBOOT 0.98
Downgrade to hboot 0.97
Hello frnds,
I have been using Droid Inc2 , it was OMH based and i was using it with reliance CDMA sim , suddenly my EVDO internet stops working on the phone and did some changes with NV then cell phone reboot ....
Now its stuck in BootLoop please guide me out .. i dont want to loose this phone ...
Can you please explain more what changes you did in the NV
secondly did you make the backup of the nv items before
What recovery you have on the phone presently Stock or custom
if you are on custom recovery you can try by wiping all the data if that dosent help try installing a custom rom
regarding changes in NV did that in Data section.
I have the old backup for the restoration .
I have custom rom installed but to wipe out the phone has to go in recovery mode its not going there it reboots before going there ..
In the bootloader i choose Recovery to go into recovery mode ,, but it reboots .. and keeps on rebooting ...
Here is what i did ..
1. downloaded the file and renamed it PG32DIAG.
2. placed on sd card
3. reboot in bootloader mode ..
4. it automatically pic the file and pressed volume up after that power button ..
5. Still same condition ...
please guide me have it missed any step ....
Here is the Link to 2 different custom recovery both flash able via cable in fast boot mode just run the bat file
try this & post results
I run the batch file for clockwork recovery .. file run automatically ..img sent to device ..
after reboot same .... it keeps on rebooting ..
after installing the clockwork recovery have you tried entering the recovery mode
and did u try the ext4 recovery
Yes I tried entering in recovery mode ....... It reboots ....
I don't know how to flash via ext4
I hope you are S-OFF already.
use fastboot to wipe your phone's data (fastboot -w) and flash complete ROM (suggest Verizon) using hboot. If this works, Its nice else you need to S-ON again and S-OFF back. Nothing else would work !!!
@kapil ji kindly please give me the link of any post with step by step ...
that will be very helpfull ...
thanks
