ramtech
Videocon d2h SPDIF to 5.1 connection in HD
Dear friends
I have bought videocon d2h hd connection.
It has 5.1 sound output through HDMI and SPDIF
I want to connect audio to 5.1 speaker system like edifier 5000pro
it has only 5.1 input no HDMI in or SPDIF in
Can you please suggest a solution how to connect 5.1 connectivity to speakers
Possible solution can be using 1.SPDIF to 5.1 convertor
HDMI to 5.1 convertor
Dear Ramesh does it have Optical Input ? Im using analog to Optical Converter for LG Bluray player, you can try that
Dear Ramesh from the information I have collected if your edifier has a co-axial point use a good co axial cable and connect videocon d2h spdif to coaxial and your 5.1 channel should work good
There is no hdmi input, no spdif coaxial or spdif optical input
Edifier has only stereo input and 5.1 analog input
@ramtech Your Receiver is useless then, as HDMI SPDIF Coaxial / Optical is must in 5.1 world
Convertion will delay the Audio and you might have lipsync problem too + loss on edged of frequency !
I rather advise you to go for Better AVR
BTW Videocon D2H only output 5.1 on Coaxial SPDIF and in HDMI if only gives Stereo ! so try to get any Good RCA Coaxial Cable for SPDIF output and compatible system for input
