Dushie
How To Unlock Tata Photon Max Wi Fi EC315 Wingle CDMA Data Card
Yes all unlockable
Also rev b working
sent by :- huaweitrick02@gmail.com
I got an unlocked EC315 (Tata photon max with WiFi).
How do I change from Huawei dashboard to something else (which allows me to send SMS)?
Also, can someone recommend a nice antenna?
Edited by vakharia
I was able to get com port for EC315.
After plugging in the data card, start any updater exe.
During search, it kills the RNDIS service and changes the mode of data card.
As soon you see two 'Huawei Unknown Device' being created in device manager,
kill the updater through task manager or any process manager.
Soon, you will see the 2 COM ports for EC315.
Connect your device to 'Application Interface' port with DFS/CW.
My EC315 has zero SPC by default so, didn't have to bother about SPC.
But I am also stuck with the same problem: after its changed to 'RUIM only' mode, it reverts back to 'NV mode' after every power cycle.
Looking forward to solve this last problem for unlocking EC315 :)
I am also unable to get Windows 7 to make this device available on a COM port.
I don't know what you mean by "start any updater exe".
Can you please provide some more information?
Edit: Found some interesting information here: http://www.kalp.us/download.html
Has anyone used these?
What happens if you change dashboard but you are already unlocked?
I suspect that my dongle does not have Rev.B enabled.
Dongle itself is unlocked but there is no way to figure out if it is connecting to Rev.A or Rev.B tower.
Edited by vakharia
EC 315 provides a web based dash board, accessed at 192.168.1.1.
It doesn't have any installable dashboard like you see in other data cards.
these data card will be unlocked.
for using. rev b
also work in nv and sim.
mode
I have seen several dashboards for Ec315. For example Smartfren allows SMS to be sent. The Huawei one does not.
yes smartfren. also allow. us to send sms
