A topic to discuss diego..
Help required here though!
Can someone help me to understand why i m not able to access any buttons there even when my cell's (N6275) connected?
Screen Shot attached...pls help!!
Edited by theking
Just use Diego 3.09 you r using very old and incompatible version
To all Esteemed Members !!!!!
Please also tel me that what types of files can we upload in phone using Diego 3.09.
I mean whether prl, pri, pm, tun can be uploaded using Diego 3.09 ???
Plz help !!!!!!!!!!!!!!
Done...thanx!!
Working great with USB as well as dongle!! :thumb:
Edited by theking
pm and tun file can be loaded only after Dongle is Loaded esl PRL and PRI file can be exchanged
did any one experiment more with 6275??
anyone tried changing the setting for video clip recorder settings to mpeg4?
does diego works with gsm phones ?? i tried it with my nokia 6230(gsm) but it did'nt work. Is there any s/w like diego for gsm ?
Diego would work only with CDMA..
Further, i modified the sms character length to 256 in my 6275!!
Just changed the length in the sms send menu!!
Not sure about diego,but you can load/write tun files using phoenix without the dongle,offcourse with the dongle crack.
Badly in need of Diego....unable to find it anywhere on the net.
Can somebody pm me a download link?
Just Google it "Diego 3.09" :Decepcionado:
Just Google it "Diego 3.09" :confuse:
Finally succeeded in dopwnlaoding Diego. But, now while installation, it gives message that "version of PC connectivity driver is newer than Diego, hence installation will not continue" and it aborts. So unable to install.
Would ver 3.08 work with 2865?
Uninstall everything related to nokia - PC Suite, Netconnect drivers. Restart your computer, install diego, and then reinstall PC Suite etc etc.
I tried this...even installed diego succesfully.
But when I run the app, it gives an error msg " Unable to locate Nokia service cable. Exiting applcation" and exits.
Now what could be the reason? Have I got the wrong version? (although it is 3.09)
Reliance supports sms upto 170 characters instead of 160..
i increased the limit to the max i.e.265 from the sms settings..but i can send 170 chars..more than that is not accepted by reliance network!!
Try to Patch the Crack
Thanks HP..finally it is up and running.
Was trying to read data from Nokia 6235 using diego. But as soon as diego connects to the phone, the phone goes into bouts of repeated rebooting.
Is anybody else also facing the similar problem? And what could be the solution?
Myself too facing the same problem......
Guys,
I am facing a problem in installing Diego 3.09. After @50% installtion, system is saying :
Error 1713:Diego can not install one of its required
products. Contact your technical support group
Pl help me in installing the same.
thanx a ton.
Need a crack
try googling ...you would easily find it. Uploading a crack is against this forum's rules.
Use Diego 3.07 not Diego 3.09
