lostjournal
Suggest Me A Smart Phone
HI all,
After staying for almost all my life with CDMA, finally I want to move to GSM.
I want to avail good data services which currently no CDMA player is giving.
I am planning to make use of EDGE network of airtel and I will be getting this for Rs. 1500 for a year( unlimited).
I have tested this and was pretty impressed.
Later on 3G. :Sorprendido:
Now I have done a lot of research and found out that E71 is best available option. The price tag of 19.6K is worth the penny.
I want suggestions from you all. Can any other 3g phone match the features available with E71 around the same price tag?
Also if someone can let me know when E63 will be available in India and at what price tag, i would be grateful?
Browsing, exchange server support, IM support, You tube on the go, is all I am looking.
GPS, Camera is not the priority. However it is welcome.
Iphone, Omnia, Xperia , HTC touch diamond, pro - I dont have the budget.
Please help me choosing the phone.
Nokia E71 would be perfect in your case. You can also try Nokia N82, very impressed with it.
Can u confirm this ultd edge plan @ 1500 for the year? Pls share the plan details... Looking for something similar to use with my iphone
@lostjournal
My dear friend, Nokia E71 could be the best bet for you.
same here go for nokia e71 great value for money phone......
even nokia n82 is good enough but i m not satisfied with its build quality.....though it has gr8 camera capabilities.....if camera is not ur priority e71 is awesome phone with gr8 built also the thinnest smartphone available in market .....
even e66 is good enough but no qwerty
e63 shud b around 14-15 k when it is available but it is thicker and looks plasticy as compared to e71
Buddy, its a corporate plan for UST Global, here at trivandrum.
250 unlimited for a month
600 unlimited for 3 months
1500 unlimited for a whole year
thats quite cheap
thats quite cheap
Probably this is the only reason for my sudden transition. Also reliance GSM launch is round the corner.
So felt its justifiable. Difficult to separate myself from reliance though. For some reasons - its quite addictive.
Anyways today nokia launched two more colors for E71 in the europian market.
Dont know when India will see this.
oh so a no go for me here !!!
I dont agree; On my Mogul 6800 on Reliance, I can do everything and more than my brother does on his Nokia E90 on Airtel...
Edited by dkaile
Which data plan are you using? R-connect? I mean how do you surf? unlimited and at will..
I use Rel MobileWorld to surf at my will through my phone @10p/10Kb (till we last know, latest rates and service - presently fluid and under dispute) and for my laptop (if needed in emergency or on the move) I use Rconnect @60p/minute.... My usage is for checking emails on the move only and slight browsing....
If u have unlimited DATA, trust me u wont regret Iphone. as with E71 there will be a day when u ask for bigger screen size.
Go to ur local market and search for used 2G Iphone will come around 15k. and join the league.
Iphone is one device everyone should try once in a life time :P He/She wont regret for it.
:Riendo:
:D:P u bet !!!
Hello Friends,
Today I finally bought the nokia E71. Its simply great. Yet to explore it.
Thanks for all the suggestions.
Congratulations my dear Sonam for your new purchase. Hope you will enjoy with your new mobile.
We are eager to have some reviews from your side. So do post the reviews after you use the handset for a couple of days.
Sure I will. Just wait for a couple of days.
E71, right now is one of the best phones you can get in GSM, except of course E90... only thing is that the keys are too small for us Indians (maybe designed for Japs)
Whats the price of E71
Around 19K, but you may be able to get it as low as 17-18K with hard bargaining...
Yesterday I saw LG KT610, price was 15410 in ezone. It may cost upto 15k elsewhere
Symbian S60, 9.1 feature pack 1. Communicator style - means better battery life. Larger key board than E71 - was certainly more comfortable than E71, GPS
I will say its E71 packed in communicator style housing and may be no wifi.
http://www.gsmarena.com/lg_kt610-2272.php
http://mobile.softpedia.com/phones/LG/LG-KT610.shtml
read reviews.
Edited by kshah
Seems OK, but somehow in this category, to have no WiFi and GPS, is not worth it... Also in this smartphones category, the quality of LG is suspect.... They specialise best in entry level phones... Would be better to stick to Nokia or HTC....
well i have been following this phone since it was announced by LG at MWC in feb.....
frankly speaking e90 is a better choice over this...the outer screen is a joke and also no wifi for a smartphone and only 950mah battery...but it has gps ( agps)
also it is s60 phone but many apps wont work on this simply coz most of the apps r made for nokia s60 phones ...though u will get the basic appps
e90/e71 is anyday better over this .....
i personally wud prefer e71 as e90 has quality and keyboard issues ....and also candy bar form factor is anyday better over moving and slding counterparts
