justanotherguy
Block Incoming Calls
Hey guys do u know is there any facility for blocking incoming SMS
i know we can block incoming calls thru security code but i want to know how to block sms coz i have someone sending me useless from few days
its high time they started a junk folder hehehe
Even if there is such facility... I dont think u can have incomng sms blocked for a specific no. :rolleyes:
my frnd who uses Nokia handset for TATA told me that he could block incoming msgs from a specific no. in his handset !! I'll find out from him, how he gets this done...
As far as my frnd remembers, u can block calls and not SMS... try the following.
Heres where u can find the option for blocking CALLS from a specific no.
Goto SETTINGS >> SECURITY SETTINGS >> CALL RESTRICTIONS ... Here u got to select the no. to block.
i think you have dialled do not disturb no.
dudes.. we weren't talking abt blocking all calls or something... We were talking abt blocking specific nos.! And tht i guess is possible only in Nokia Phones and none other... Post more info if u have on this matter... Read the thread carefully!
Hey!!!!Hi everybody.I just wanted to know the number or code which should be dialled to block incoming calls ........if anybody does know the code kindly post the code.Thanks.
do it yourself. go to rworld, go to help, activate do not disturb, you wont recieve incoming calls, but u could make outgoing calls.
I'd be more interested in knowing how do u activate it again to normal! Coz i rem delisting my no. from RIM Dir, and found that i could never enlist it again! hehee...
Earlier the no's were
*315 to Activate &
*316 to Deactivate..
It isnt working now :)
Wanna block incoming calls try this simple trick
Menu > settings > phone > data settings > data/fax >
Set the value to data in
This should block incoming calls
You can still make outgoing calls
To enable incoming calls again set the value to off
Is there any way to block specific numbers like telemarketers/banks trying to sell you stuff/loans?
Dint get you :unsure:
Do they sms you like any kinda advertisement :unsure:
There is an option in Nokia phones to block incoming calls from specific nos.(telemarketers) I doubt if theres a similar thing for other handsets!
Dint get you :D
Do they sms you like any kinda advertisement :)
actually i don't mind sms as much since its less intrusive
i meant voice calls
I've heard of getting calls from credit card companies etc to Hutch but never got any calls on my reliance phone. Maybe U had disclosed ur no. while registering for some card etc online or may have given it out somewhere
normally all these telemarketing calls will come as "restricted number" in the CLI so u can better ignore the call ;)
whats the neeeed to block calls
just answer them.the other person will pay the bill he stands to lose.while roaming, cancel these calls.
in nokia GSM SETS u can dial *#0000# and *#06# also #3370#
why cant we run these in 2280. Any company codes for nokia to try out safely?
Cauz all these codes for GSM mobiles not for CDMA!
whats the neeeed to block calls just answer them.the other person will pay the bill he stands to lose.while roaming, cancel these calls.
:o LOL Great!
Let me tell you about a security option in case you apply this with LG RD2030 handset. If you press Call button twice, the caller gets nothing to listen!
Single Press=Talk
Double Press=Mute
Enjoy!
Can U come out of this "Mute" using the In Call Menu OR End button ??
In my 5130 it seems to be permanent for that call ;)
