deepu
Problems With Skin Chooser
Forum Logic Looks great... Code you can click on the thumbnail attached by Vishal and see the problem...
The header seems cut in some parts. Perhaps the file got corrupted while uploading..
Other than that everything looks fine... Good work Code
Yah!
Code pls see the screenshot that i've attached in my post.
The banner shows corrupted image.
so pls correct it.
This problem is seen only with Mozilla/firebox I guess due to the way it handles tables :thumb: - On IE it looks perfect.
I have tried fixing it.
Also Images and links have been edited for beachcomb skin. :quest:
Let me know if it's showing correctly now :confuse:
Looks perfect now.... Great work code... Keep it up!!!!
