Karthik R
Guide To PC's Cable and Wiring
Infact a very informational thread dear Karthik Brother. +1 :)
Speaker Wire
Use it for: Connecting speakers
Add more ports by: Connecting a splitter or receiver
Strands of speaker wire--each with two cables inside--connect each speaker to your receiver. Brand-name versions are a waste of money. The gauge, however, can matter, especially when you're running long lengths, around 75 feet. Thicker wire (a lower gauge number) works best. Try not to use any excess cable, since that can produce interference. You can add a banana-plug tip to make the connection, but you'll get the same results by twisting the exposed wire end and inserting it into each device; just be sure to match the positive and negative markers on each component.
Source : pcworld.jpg
Indeed very informative and interesting.
But What type of connector is that?
Wow!! that is really exhaustive list.
Edited by kkdeep
Speaker Wire
My dear friend, its not a connector, its a SPEAKER WIRE. :)
+1 For The Hard Work...
+1, Karthik for the excellent hard work and info.
Excellent Info:)
Keep it up
