Notam
CNG Kits Suggestion
I would like to take your advice on getting CNG Kit installed in my car. Which all Kits are available n the cost involved. Just got these options
  1. Tomasetto Achille CNG Conversion Kit - Argentina & Italy
  2. Pelmag CNG Kit - Argentina
  3. Lovato CNG Kit/BRC CNG Kit - Italy
  4. Landirenzo CNG Kit - Italy
  5. Lomani CNG Kit - Italy
Edited by Notam
Most cng kits are imported. What is important is fitment. If you are going for kit with lambda controller or sequential kit then software of it is important however none of them is in user control. Ensure that they use genuine valves and piping.
LPG is not a good fuel fpr car IMO
Sent from my MB855 using Tapatalk
Got BRC installed...
Got it done in 32K... Getting an average of 25-27 on Maruti Alto K 10
Am fairly happy with the performance.
BRC ??
Tomasetto Achille CNG Conversion Kit - Argentina & Italy : This one is best as per my opinion a friend of mine had got this installed in Honda Accord and was very happy after its performance and Mileage :)
i have used LPG kits in honda and toyota and they have the following benefits over CNG:
- half the cost [rs. 20 k vs 40 k]
- 1/4th the pressure of cng so less chance of leakage / blowout
- lower emissions for fuel injection
if you don't have any lpg pumps near your home or work then of course you should go for cng instead
depending on usage you breakeven is about rs. 1 k / month on avg
so 18-19 months for lpg and 38-39 mths for cng
now it is the right time to write here as our @#$%%*%$# govt has increased the petrol prices by 7.5 Rs.
This is intolerable, may this govt fall with in 7 days, my baddua....
I am having a santro gls 2008 model and now Cannot bear the burden of petrol anymore (although i am not in favour of CNG but this is too much).
want to know the best CNG kit for my car and a good installation center in east delhi area....
members from delhi pls suggest..
^ even i own the same.. :cry:
this is really intolerable.. have to look for some other alternative now..
Lovato is a good kit, provided bought from reputed seller.
All government is same in gujarat bjp goverment hike cng price 60% within three month. Fro 34 to 53/kg .
the problem is non of the state govt and also central govt is reducing tax on fuel. Goa did it but other states are simply overlooking it.
Try ECOGAS they have multiple outlets one in kaushambi also.. my friend got his cng kit (lovato premium)fitted from them and he is happy with the performance and service..
how much he paid for lovato premium?
