sphinzm
how to activate voice stv using mobile balance
sphinzm    0
hi everyone,
is there any option to activate voice STV packs using mobile balance,
Hejmady    32
hi everyone,
In RCom CDMA, I regularly activate SMS Pack Rs.14/- by sending SMS Keyword ACT RC14 to 53739 to avail All SMS at 5Ps. & validity 30 days. you may try the same for Voice / any STV by replacing 14 in the SMS keyword ACT RC14 by appropriate Voice STV pack amount.
best wishes
csmart    453
If you are using smart phone, then you can also use Reliance Instacare app.. I used it for activating data pack and other services.
I am trying to activate and use Reliance Instacare app While I tried to register I got the OTP password , But I don't know where I need to give that password.
Can any of the member please help me how to register and use Reliance Instacare app
anbuitech    7
hi everyone,
Hi
send message as eg "ACT STV63" to 53759
sphinzm    0
tried both instacare care app and through sms but not working. am using R GSM tamil Nadu circle. suggest any working tips to activate unlimited 297 voice plan.
thanks.
sphinzm    0
instacare care app showing only one voice pack that too for roaming
M.S.Rao    64
In your mobile, Dial "" *129# "" , then a popup window of USSD Menu will open.
and follow the instructions there.
sphinzm    0
hi thanks for response.
i did check *129# for STV packs it has one STV pack that too useless.
