Guru Gopal
Huawei B310s 927 data card unlocked for all 4G networks
Guru Gopal    588
i purchased airtel locked huwai B310s 927 in olx for Rs. 900 and unlocked.  Now it is accepting all the 4g sims of india (idea, airtel, JIO, and Rcom4g) and also all 3g sims.  Except with JIO sim all other sims working not only data and voice also (landline phone can be attached to this router) Jio working with data only.  It is covering Nearly 100 feet area (through Wifi). This may be moved to appropriate Thread.
  • Like 5
mgdelhi    191
Thanks for the useful information.
Do you what other models of Airtel 4G dongle can be unlocked to use with Jio ?
KanagaDeepan    1,050
Does that support band 5 as well ji?
sent from my Lenovo vibe P1 using Tapatalk
Guru Gopal    588
Rcom in my area not working on Lte 3 or 40.  only on LTE 5.  Though the spec page of this modem is silent about Band 5, still it is working with Band 5.  i.e. RCom 4g
Guru Gopal    588
almost all airtel 4g dongles unlockble, except some came with new firmware.  I used dc-unlocker dongle to unlock it.
LTE4G    158
Are you sure that it supports Band 5 ?
If so I can also go for it.:wub:
KanagaDeepan    1,050
Yes, it supports all 3 bands [3, 5, 40] and I am using one...
LTE4G    158
Thanks! for the information.
mgdelhi    191
Thanks.
Edited by mgdelhi
caringlover    32
Hi, is there an option of Port forwarding in this Huawei device
Dushie    30
I am interested in buying the same for using with Jio, is it easy to unlock on your own as i heard you need to do some firmware update and make changes for it to accept jio apn. Can you share the steps or guide how to go about doing the same. Unfortunately in my area i am not finding this model easily and where it is available people are asking too much for the same.
Edited by Dushie
Dear Guru Gopal.. which firmware version you used to make voice call. As i am unable to make these..
