jusmail
Speed Dialing In 2130
If you assign a speed dial entry from the phone book menu, the same number can be dialled by simply pressing that assigned key for a long press,say 3 seconds.
that means if u program number XYZ at 1 key,keeping 1 key pressed for 3 secs will automatically dial XYZ.hope this helps :clap:
:P what is to the speed dial limit on your phone?
9
or
99
or 999? :clap:
Speed Dialing lets you select 9 of your most used no's and assign them to the 1-9 keys..
Hope you got that jusmail :clap:
On my 7130 there are 99 speed dial slots.
If U want to say.. dial 59 th No. Press 5 then 9 and hold it down until it dials :)
In my Nokia 2300, if i've to dial 2-digit no. like 65, then i type 6 then 5 and hold 5 until it dials the number. Same as code mentioned.
jusmail RD 2130 is having 99 speed dialing slots :)
Go to the address book and press top left button and select speed dial
and select any slot or type manually
afterwords just press that number for ex: 20
and immediatly if u press dial key it will dial the number assigned to it
or if u press top right key type SMS and u can send speed message :o
If this is not happening in your phone then i think u'r software is not updated
