Mukeshlst
Call Diverting Not Working.
In my gsm prepaid i am able to divert my call at any no since last one week.please help.
Inform the way you have tried
Goes to
call setting > call divert > all voice call > to other number (typed no)
its say not done
If you want immediate call divert
then press *303 followed by divertee number.
To cancell this facility press *308
If you want diversion after 10couple rings to
your handset then diversion press *30l followed
by divertee number
Read topic carefully i am asking for GSM
Maybe in GSM also same proceedure. First you try.
If not worked then contact GSM customer care
Mr. M S Rao,
For unconditional call divert, it is*301 and for not reachable, no reply, call reject call diverts, it is *303. To cancel any kind of call divert, *308. But if you want to cancel only unconditional, *302 and for not reachable *304. Similarly for CD on call busy, it is *305 and to cancel this *306. In all cases except cancellation, add the mobile number or the STD code+LL number. However only within circle numbers can be used for call forwarding and not any STD mobiles or LL numbers.
The above procedure will not work for GSM.
@mukesh,
Did you use a STD number for CD? It will not work or maybe you used a number series (like 90,91,95, 96) which has not been updated by RCOM. Try dialling out that number from your RCOM GSM phone without the '0' and if it goes through, then CD should work properly.
*301,*303 or *305 work in cdma not in gsm.in gsm we can divert threw mob only.
This is exactly what I have mentioned in my post. Read once again.....
Mr. M S Rao,
Dear Mr.KumaarShah'
Thank you very much for the information
I said its not working since last few days mean i know how to do.but now these days its not working.
Then the only way, complain BSNL people at Toll Free No: 1991
(In some areas this number may differ)
I diverted calls from my GSM umber to CDMA number. It worked for 1 day but later it cancelled itself.
the reliance gsm service systems are not ready to use yet they are still in testing status
:previous:
If true, this is very bad after the national rollout...
I had the problem with Vodafone prepaid.. they told me the call divert wasnt available in prepaid.. it was quite some time back..
Best of Luck...
One query, it used to work before and suddenly one day you are finding that it isn't functioning?
