SumitVerma
Help: Htc Hero Messages Issue
as usual ... sadik's the man!!
Started my own number in there. Messages Issue not yet solved. Same Force Close thing is there.
also notice if it gives switch off tone to the callers after long hrs of been idle
I would suggest you put a reliance no. on this phone for some time to rule out any hardware issues; if the problem vanishes, then again change back to tata; if it persists then it should be a modem issue with your phone...
Had words with Sadikk bhai. He asked me to mail the phone back to him and he will work over it. Thanks Sadik Bhai. And thanks a million trillion to all here.. You all helped me too much.
Will update as anything new happens.
dont worry yaar...all iz well :winko:
Thanks... That really makes me feel better!
NO No aaaal iz well :Contento:
Sumit i got ur phone... and using my number in it.. and its working fine..
No problem whatsoever.. SMS, Calls, Calls in Sleep mode.. all works flawlessly..
I think its some issue with TATA... lmk what to do..
You tell me sir! what should i do?
Ill try to transfer TATA number on it.. and retest for u..
Phones Radio, Modem and everything is perfect..
Not sure ya...
Update!
Purchased a new Tata postpaid connection of Haryana and activated it while the phone being in Mumbai with Sadikk bhai!
It was all working fine their on Reliance as well on Tata, messages issue was no more there.
Now when the phone was back in my hands, the same issue started all over again. Same network went off and on and force close message.
Last day when I went Delhi, I was able to receive messages and felt happy thinking the issue is resolved, but when I am back in Haryana, the same issue comes again!
Kindly Suggest what to do!
This is a video I made for the Reference.
Youtube Link:
It seems as a problem of SID and NID that Tata uses; as Reliance uses single SID and NID whereas TATA uses multiple;
you can experiment by changing the SID and NID by going into ##3282# (i.e. ##DATA#) and edit the Advanced settings after entering your SPC;
Try using the following combinations of SID and NID for Tata -
(Set the Pairs as per Below)
Home Home
SID NID
14846 65535
14842 65535
14840 65535
14836 65535
14844 65535
14838 65535
One of these might work out for Tata in Haryana...
Edited by dkaile
Sir just checked with QPST as the phone just shows the 1st one only and all the SID/NID are configured properly.
What else should I look for apart from this?
Edited by SumitVerma
In QPST>CDMA Tab> Terminated Registration, HOME SID, Foreign NID Foreign SID all are checked!
try changing the first value of SID to different values...
I have started receiving another Error:
Error V08, Voice Message will be delivered when Data Services will be available.
Tried to change the 1st SID to different but no gain.
One thing, I did it from the phone itself. So it means when I tried there were two same SID in the phone at different Numbers.
Another thing, I am using Touch Diamond with same SID/NID and its working all fine!
revert all settings in qpst so as to get your voice etc. working at least... unique problem...
my voice calls are working perfect...
The Only Issue is texts.
But I was saying when I recieve the Texts, It also shows the voice Message error with the force close Messages.
