SumitVerma
Help: Htc Hero Messages Issue
Update:
Just loaded up Damage Control v2.0
Source: http://forum.ppcgeeks.com/showthread.php?t=115976
And have started receiving texts! Hurray!!!!!
But having another weird issue! my mobile number is
zero nine two one five two zero two two two two
but when I receive the text, its showing as D nine two one five two D two two two two.
Another issue with the rom: Sorry! The application Setup (process com.htc.android.htcsetupwizard) has stopped unexpectedly. Please try again.
Doesnt let me access the menu but I can enter the dial pad.
Dear ones please help me out. Really I need help of you all.
Edited by SumitVerma
I think our's this is a ROM issue. try another rom. I was getting same issue on my magic. Now using SuperD and have not faced this issue since 5days.
Sir what issue are you referring here?
The HTC Setup Wizard one? or the Messages one?
My main issue is the messages one! I could always roll back to the older rom or switch to some other rom! but I am receiving messages which is my main concern as of now.
Just noticed that still the network goes off and on when I receive text
I would like to suggest, to a clean wipe of your device,
Install a proper radio and rom, only choose good combination of both
Sir, what rom do you suggest? Acutally I havent yet updated the Radio as of now! If my mistake i ever switch back to 1.5 rom, It will just brick the phone as said in other topics!
Kindly suggest me a rom and radio which I should use.
I have downloaded this Radio: http://forum.xda-developers.com/attachment.php?attachmentid=291042&d=1268100724
Flashed With Damaged Control 2.05 as guided by Mufaddal Sir!
Now I am able to you the handset, Still able to receive the texts but in same manner (Shows Zero as D)
When I try to flash the Radio (2.41.04.02.03)
android system recovery says
E: no signature
E: verification failed
Installation aborted
Do we need to do something to the file?
Downloaded a different Radio as instructed by Hitesh Sir and flashed, there is a typo in that radio it reads (Baseband 2.41.05.02.03)! Works fine. The Messages are still the same. Shows "D" instead of Zero!
where did u get the radio from
it might not have been signed properly
also there are two versions of radio
one for eris leaks
and one for others
Update:
I am back in Delhi now! Able to receive Texts properly with proper numbers. Zero shown as Zero, Not being Replaced by "D" as it happens in the home network, Haryana!
tumhare hero ne sab to confuse kar rakha hai :Equivocado:
this means the problem is only in ur home network
If it is so, then why Dont I face issues in other phones like:
TP2, Diamond, Touch, Treo Pro and phones provided by tata Itself like 6235 and 6275?
i think you should wait for official update from Sprint,
after getting it, delete all data from it, install appropriate Radio and install new official ROM.
Also i would suggest try diffrent TATA PRL if possible.
Thanks for the suggestion!
I am eagerly waiting for the official Sprint ROM.
One question though will it have the Radio aswell in there or what?
BTW I have already upgraded the Radio!
i know you have already updated the radio, but new rom may require radio update, just wait
i think this 0=D issue is not too big, at lest you are getting txt msg.
Thanks sir, Makes me feel better now!
new radio available for hero , Ver 2.43.00.03.10 for all roms
you can try that !!
no, its not a typo.
New radio is Ver 2.43.00.03.10
Do you mind leaking out the link sir? That would be a great help!
its was an typo, radio is HeroC-Radio-2.42.00.03.10
Edited by ::Hitesh::
Update:
Now am back to the Home Network.
Just received a text from Face Book (5155505) Zero shown as Zero and not "D"
congrats sumit... its been a long torturous wait for this.
we hope this stays and the problem is gone forever.
Thanks. I wish that this Zero="D" bugs settles down soon aswell!
So I could Shout out loud " Bhaiya Aal Is Well "
HI Sumit Please Post Buzz to me I have a New Logger Software and give me the Dump of Log when u receive the SMS Crash
I will send it to Core Android Git hub Bug Tracking Site
