ami1
Advice Required for Verizon BlackBerry Z10 on Reliance CDMA
Is it possible to get a Verizon Blackberry Z10 to work on Reliance CDMA once its MEID is registered ?
Or does it need extensive programming etc ?
If possible, then will there be any issue of PIN (say in BBM or appworld) ? though BES/BIS is no longer essential now.
Reason I am asking is that I have bought a Z10 (GSM) but my office number seems to be having issues in getting ported to Reliance GSM.
Lot of verizon Z10 are available (even with unlocked GSM) and I am thinking if my porting doesn't happen then can i buy a verzon z10 and use on RCDMA ?
Gurus, Please put in some advise here. Even if it is to confirm it can't be done. so that I can decide accordingly and shift handset or something.
I am FED UP of vodafone 3G now. Everyone in my building used to say its great but its really ****ty. For a few days I even thought I need to get my ears checked :(
I think once you have tasted CDMA its pretty difficult to go to GSM. Unless they come up with full 3G coverage and HD Voice. Only data is faster but then as soon as I enter my house its on Edge, though just outside the door is shows HSPA+
Have stopped call forward from my main RCDMA number to my BB Z10 now as I can't make out what's being said.
Don't have answers to your query but making some educated guess just to make you feel happy that someone replied. :)
  • I think none of the gurus can answer conclusively unless they have the handset in hand and check out the possibility. Olympic.gif
  • Most of the gurus may not get the handset in hand because of shortage of buyers for blackberry Z10 except die hards like you. Bar.gifFireworks.gif
I have been searching for the one that works on RCDMA.
STL100-4 model looks to be for CDMA.
Even I was searching the same and didn't get a clue.
There are few sellers mentioning STL100-4 availability online.
Don't want to take this risk for Z10 as I been with RCDMA since last 10 years.
Let me know if you have any update.
Thank you.
It works on Reliance,
You just need to get it unlocked,by an expert,
I've a person in my city who sells z10 and q10 in reliance cdma.
I've seen it working,
@nakul were arevu from?
How much for z10
Thanks for the info. Which city ?
STL 100-4 is verizon USA z10 model
comes factory unlocked for GSM
RELIANCE CDMA OMH SUPPORT VERY WELL
BUT ONLY CALL SMS AND 1X no EVDO.
I am using same model.
Just to use calling facility,I dont think you require to get the meid registered or anything.
Just wipe the phone completely and pop in the cdma SIM.
You need to wipe the phone for it to latch to cdma network.
