manishdk
Which Blutooth Device To Use With 6275?
I have one question guys ..
Which bluetooth device I should use with my pc to connect with Nokia 6275 ?
I already have downloaded Nokia PC suite (latest one) for the phone.
I bought one small bluetooth ..some China made .. for 250 bugs..
It had Widcomm drivers.. Drivers were successfully installed.
It detected the Nokia 6275 ...but while transferring data from pc like mp3 songs.. The connection was getting lost again and again ? I got frustrated..
Is it ok to transfer mp3 of say 4 mb each using bluetooth or using USB cable ?
Can some one help me to find the right bluetooth device for Nokia 6275 to be connected to my pc.
Thanks.
I got the solution..
Replaced that sTupid blutooth device
with USB cabel..
Data Transfer Successfull.. <_<
Edited by manishdk
Which Bluetooth HEADSET is good for 6275 ?? Any users ???
:Sorprendido:<_< i bought NOKIA BH 900. it is working perfectly... i tested many other bluetooth sets (Nokia) with my mobile(6275).. its working
I am using the Nokia BH-800. Although expensive, I find that is perhaps the best I have used. It is small enough that you hardly notice the wieght, and you can wear it all day with no discomfort (which is what I usually end up doing). The provided wire ear loop is also pretty comfortable.
The only slight downsides I have to mention are the high price and the somewhat limited range.
Other units you can try are the Nokia HS-36W (clunky after the BH-800) and one of the number of units produced by Jabra.
Try the Moto HT820 - the sound quality ROCKS!!!!
Thanks for reply.
Can you please quote rates for Bluetooth Headset.
Moto HT 820 is available around 3250 /- odd.. (ebay)
i too am willing to purchase a cheap but good bluetooth handsfree for my 2865 . . .searched on ebay and all just found orchid cheapest . . . . . .ne suggestions
Thanks.
Every body forget this main topic of the person who started. I m also facing same problem with my new 6275 phone. when i tranfer big files it discnnects. even when i want to see phone contents from computer using bluettoth it discnenct now and then. Any other user of Nokia 6275 having this problem? Anyone got any solution?
Edited by rakesh5295
well at times it disconnects for me too bt i am a 2865 user
Hi Rakesh,
My self the original poster.
I replaced that bluetooth device with USB Data Cabel..
When I try to transfer a 15 mb music files from Sony 750i in my nokia 6275 via bluetooth it worked fine. No disconnection at all.
But those devices which are available in market which we connect to pc are not good so got a USB data cabel.
the problem it gets disconnected is hat the software u r using is trial version.. it does nt support file transfer of 5 mb n above with BT... download a cracked version of blue soliel n connect.. ll work fine.. i myself do it..i got the device for 22o bucks too...
