Arun
Invision Power Board 2.0 Installed !
Those links doesn't seem to exist now. Most probably, it must have been deleted.
So why don't u edit Niket's post & remove those lines or edit them, so that no one faces this problem again in future?
Can you please check it now ? I've done some changes in the codings (in Default skin)
Now its working properly! :clap:
Edited by Vishal Gupta
Mods & Admin.
Can u add one more option Handset model under the members avtar, like all other options (Group, From, Posts, Joined, Member No)?
I hv seen such option in many other mobile forums.
It'll be very useful cauz then all members will know which members has which mobile set.
Is it possible?
If there is some limit of options then u can remove other options like Member No.
So pls think about it.
29017[/snapback]
Your request has been done successfully by Ashok ! ;)
Now you can view the handset too under the member details ;)
Your request has been done successfully by Ashok ! :P
Now you can view the handset too under the member detailsĀ  :D
30301[/snapback]
Damn kewl ! ;)
Thnx Arun & Ashok!
GOOD job!!
LAGE RAHO!!!
But Arun can the Handset model be displayed just between the Group and Posts option?
I'll be very nice if u will do that!
But Arun can the Handset model be displayed just between the Group and Postsoption?
30408[/snapback]
Sorry, it is possible to add the new field only after the default fields.
Arun!
Can the limit of at least 4 characters in search box be decreased to 2 or 3?
For example if i want to search the threads which hv SMS word in title and write SMS in search dialog box, it should show the threads.
But instead of it it shows ERROR:
One or all of your search keywords were below 4 characters or you are searched for words which are not allowed, such as 'html', 'img', etc, please go back and increase the length of these search keywords or choose different keywords.
So can u allow to search with less than 4 characters?
It is currently set to 3 characters. If you are unable to get any results, try using wildcard. eg: SMS*
But when i tried to search using SMS* in the title, it showed following threads:
>India's Fastest Smser! Will It Be You?
>Smsing With Nokia 3105, Whats the fastest way
>Concatenated Smses Sent To Rims, Issues relating to SMS size limit
>Till when, SMSs are free for DAPO Users ?
Even there r some threads, which hv SMS word in their title, like:
>Non SMS Stuff, Amusing Irrelevant Stuff here...
>SMS, Post anything upto 160 characters only
Why it didnt show these two threads in the results?
So pls do something so that we dont need to use wildcards in the search string.
There is nothing more that can be done regarding it. I can't contact Invision Power Services regarding this issue either, since we do not have a license.
common vishal, u trying to find a bug in ipb ?
lol, leave it.. i guess it doesnt matter much...
not much people depend completely on the search. :(
But Search feature is required whenever we hv to find the right thread to post something. Right?
That's why i searched for SMS, cauz i wanted to post some good SMS and when i searched using SMS and SMS*, it didnt show the right thread that was required.
Anyway no problem!
Next time i'll search manually for the right thread! :(
I saw in nother forum, that we can know in a Poll thread, who has vote for which option!
I mean there is a link present under the categories, upon clicking on it it shows each member name who has voted for which choice.
I'm attaching a screenshot!
Can this be implemented in our forum also?
It'll be gr8.
That can be done using a mod in IPB. But I feel poll votes should be anonymous, so it isn't a good idea to implement it in the forum.
Is there any limit on using Quote tags in a single post?
I used 11 quote tags in one of my post, but it didnt quoted the portion, instead it showed "[q u o t e]my text[/q u o t e] (without spaces)", even i carefully closed the quote tag.
When i replaced quote tag with code tag, it worked without any problem!
So pls check it!
I'm not aware of such an issue with Invision Power Board. Can you point me the post where it occured ?
[ Quoting the discussion on the Search Feature in IPB inĀ  Posts 108 to 113 ]
This might not be the best method around Vishal . but u can rely on Google's search. but only after it gets to crawl all the posts on Rim web
for ex:
http://www.google.co.in/search?hl=en&q=sms...le+Search&meta=
gives only 2 results. but good search... ( i used the google search tag - inurl )
<<EDITED - Sorry didnot quote the actual post initially.. its done now ! >>
Edited by swaroop
What r u talking about?
I can't understanding!!!
I meant with
tag, that we use whenever we want to quote something in our post.
hmmm, not sure, maybe they have a limit.
<TESTING>
Now its time 4 my contribution! :D
11 gr8 tiny utilities!!! :clap:
1. Resource Hacker
Resource Hacker is a freeware utility to view, modify, rename, add, delete and extract resources in 32bit Windows executables and resource files (*.res). It incorporates an internal resource script compiler and decompiler and works on Win95, Win98, WinME, WinNT, Win2000 and WinXP operating systems.
D/l Resource Hacker
2. KLox
U can use KLox to display a good looking Clock on desktop.
D/l Klox
3. Boot XP
Boot XP is used to change the Default Boot Screen of Windows XP. U cab change it with any of ur favorite Wallpaper.
D/l Boot XP
4. Microangelo
Microangelo is used to edit the Icons.
D/l Microangelo
5. Hex Editor
Hex Editor is used to edit EXE, Dll & other files in HEX format.
D/l Hex Editor
6. Clearer Type
Clearer Type is used to set the contrast of fonts in Clear Type display. By default Windows XP sets the contrast too high that fonts r looked very ugly. U can change the contrast with the help of this tiny s/w.
D/l Clearer Type
7. File Spiltters
I'm attaching two File splitters (HJSplit, JASP). Both r gr8. U can use them to split the files, that r larger than the floppy size so that u can store them in more than 1 floppy, And u can also join them while restorin them on PC with the help of these s/w.
D/l Two File Splitters
8. Revelation
Its a gr8 s/w. It is used to show the hidden password (Asteriscs) in Text boxes.
D/l Revelation
9. Read NTFS
U can access the NTFS partition in a FAT partition with the help of this gr8 DOS based utility.
D/l Read NTFS
10. PC Inspector
Hv u deleted a necessary file from recycle Bin? Don't worry, with the help of this s/w u can retreive the files, that u hv permanently deleted from Recycle bin.
D/l PC Inspector
11. XOSL
XOSL is a type of Boot Loader. U can use it to dual boot ur system.
D/l XOSL
So ENJOY!!! :yes:
<Now tell me whats wrong? Although all QUOTE tags r closed properly!>
Well
QUOTE is mainly meant to use while you want to bring into attension some old post or something which has already been posted. Normally, or may i say it would be ver very very rare that u need a 10 or 11 quote in your post.
Not a big issue..
if needed more, you can use CODE
I guess it doesnt make any difference, except that in the top it says CODE instead of QUOTE.
Yah!
Very true. Its very rare to use 10 or 11 QUOTE tags in a single post.
And I hv no prob in using CODE tag instaed of QUOTE tag.
But I found this new thing in IPB & thought of sharing it here.
Thats it! :clap:
