This thread has been opened to clear all the doubts regarding using DATA Services on Reliance CDMA Phones. I see many members seeking for help to know details about the plans, or many members ends up making huge Bills due to wrong plan selected or wrong PPP used.
PPP plays an important role while using the DATA on CDMA phones, its same as like APN in the GSM. The PPP you will use, you will be charged as per it only. There are two PPP :- RMW PPP and RNC PPP. If one use RMW PPP by taking RNC plan or vice versa, it will end up in huge bill or sudden decrement from Prepaid Balance. All PPP settings are initially done by your seller in case of Imported Handsets and are set to RMW in case of Proprietry Reliance Handset.
So carefully choose the plan and use the PPP Accordingly.
All plans listed can be used on the phone or tether to your PC.
Any member can ask the question about the same if there is any doubt and all queries will be answered and solved within 48 hours.
Regards
Amit Jain
RIMweb.in Member
POSTPAID:
PREPAID:
Prepaid Rs.5 pack discussion: http://www.rimweb.in...a-mobile-users/
