nikme
GSM Radio Finally Unlocked For Motorola Droid Razr, Droid 4, Razr Maxx
Gsm radio finally unlocked for droid razr,droid 4 and razr maxx(havent tested maxx yet)
Now these A-list phones are truly global.
why wait for verizon to release there global rom when we can do it right now.
1.Data-Working over edge
2.Messaging-Working
3.Calling-Working without any issues
4.USSD-Not Working
5.Cdma Omh-Havent Tested yet though it should work will try it and update here
So how we do it
step-1 root your phone with motofail
step-2 install bootstrap recovery
step-3 download this zip file and put it into the root of your memory card
step-4 boot into recovery and install the zip manually
step-5 put your micro sim in the sim card slot and resatrt in few seconds it will recognise it and will start showing network bars
step-6 manually enter apn setting for data
tweak a little bit according to your need and you have a working gsm phone in your hand will update soon about cdma omh possibilities
Using droid 4 since 2 days and its working flawlessly.
If you face any difficulties doing it post here i will try to resolve it.
more updates and tweaks coming soon.
p.s -Dont blame me if you have a sleek brick in your hand if somehow it fails :hypocrite:
Thanks xda for giving us new possibilities LINK
Make Calls & Confirm the Voice Quality as People Say Voice Quality is Worst by this hack
Droid Bionic is the first handset which got GSM working and this made way for Developers to try Droid Razr & D4, But it does not work with all SIM cards. Options are limited.
May be we get a Custom ROM soon specially for GSM. Till than its not so reliable.
Yes CDMA omh does work flawlessly. Data can also be made to work.
gr8 news.
i did HTC rezound gsm unlock process . working flawless without any issue.
at evening i'll try this with Razr & i'll update you all.
10th of June i'll receive 50 Smartphones for sell.
Voice quality awesome no issues and I am using droid 4 with airtel
Very stable.
@javed Droid razr already tested and working fine
@kapil I think its reliale as I have tested with airtel and vodafone microsim no issues with them
Don't have other microsim in hand to test and voice quality was not a problem with these operator
Yes this was started for bionic by manually entering the string with radicomm but droid 4 is sucess as per what I have tested.
@parin bhai maxx pe testing karlo aur kisi ke paas to razr maxx milega nahi aapko hi test karna padega.
Will i be able to use omh and gsm interchangeably or only gsm will work after this ???
Sent from my HTC One X using Tapatalk 2
@nik how about data & sms?
If you got success for Razr, then that same procedure ditto applies for MAXX also, as both are using same ROM, everything from the beginning... But if you want to confirm, discuss with Parin ji reg the procedures as u have said earlier, he is having one MAXX now with him....
@himashu change the sim and it works
Still nothing for the Droid 2 Global :(
But Dorid 2 Global already has GSM
Tried on Maxx but No Sucess
Edited by parin
Even razr is not stable got freqent reboots problem and network fluctuating
This concludes only droid 4 is success with this method until further development
Stay away doing it on razr.
Maxx seems not to have GSM support
Yep parin - but its locked. and the unlock codes are reupdated post sale via OTA. U need to get codes from Verizon itself - and many of the codes they issue don't work. :(
cheers
AK
tried on RAZR only calling and Messages works But I can not latch to Vodafone Internet with www APN though it works perfectly on my One X
Data worked with airtel sim on razr.
does razr support BSNL 3G?
Razr stil unstable and under development will update soon.
Hetalbhai My razr is working perfectly with vodafone Edge data, will try 3G but they have outage.
Maybe changing mode to wcdma preferrred in phone info might do the trick.
^^^ 3G also works, dl 3 mbps and ul 1.5 mbps
A little help required.
I changed the gsm band of razr maxx to US band thru Phone info app and now it is not accepting Vodafone sim, any idea?
Razr maxx doesn't work on gsm after the fix as reported by parin
^^^ thats strange, thought the only difference in razr and razr maxx was the battery and even the roms are same.
My Razr Maxx did work but no data, and calls showed error of "OUTGOING CALLS ARE RESTRICTED BY FDN".
BTW razr has been working perfect for a few days now including 2g and 3g data on Vodafone without any problems
Razr ICS coming on today on verizon...
