panku_etc
Reliance EVDO/1X Data Issue
^ Any idea what was the issue? Might help others too....
it seems one or some of their DNS servers are not working. check the trace-route results below
while the issue was there:
MacBook-Air:~ user$ traceroute google.com
traceroute: Warning: google.com has multiple addresses; using 173.194.36.37
traceroute to google.com (173.194.36.37), 64 hops max, 52 byte packets
1 192.168.1.1 (192.168.1.1) 1.987 ms 0.893 ms 0.949 ms
2 220.224.141.145 (220.224.141.145) 2674.559 ms 3153.105 ms 3220.978 ms
3 115.255.16.242 (115.255.16.242) 3186.366 ms 3543.189 ms 3006.693 ms
4 124.124.239.189 (124.124.239.189) 2953.261 ms 2932.817 ms 3422.882 ms
5 * * *
6 * * *
Current results:
1 192.168.1.1 (192.168.1.1) 2.340 ms 0.995 ms 0.965 ms
2 220.224.141.145 (220.224.141.145) 1719.847 ms 2181.288 ms 2221.710 ms
3 115.255.16.242 (115.255.16.242) 2301.101 ms 2343.985 ms 2333.725 ms
4 124.124.239.189 (124.124.239.189) 2368.839 ms 2377.665 ms 2357.938 ms
5 115.255.239.49 (115.255.239.49) 2014.197 ms 2367.273 ms 2732.230 ms
6 72.14.212.118 (72.14.212.118) 2714.630 ms 2916.471 ms 3014.878 ms
7 72.14.232.202 (72.14.232.202) 2868.926 ms 3280.390 ms 3045.573 ms
8 209.85.241.189 (209.85.241.189) 3180.173 ms 2704.435 ms 2745.059 ms
9 bom04s02-in-f5.1e100.net (173.194.36.37) 1981.791 ms 2656.034 ms 2769.432 ms
Which number did you call for CC and what did you explain them your problem as? When i try calling them they keep on saying Motorola is not a evdo enabled handset :-(
it is 198. i got the person who understand the issue in my 7th try!!. also tell them that you are using samsung galaxy pop or corby.. otherwise they will insist the handset XXXX will not support EVDO :doh: . Again i had issues this morning too.. now it is back online. so it might be ongoing...
I had called CC on *333 in morning 7:00 told them i have issue with my EVDO. Handset as Samsung pop. And by 10:30 issue resolved.:-)
Never expected such fast response... (i guess i was lucky...)
I think the issue solved now . FOr the past 48 hours I am using EVDO without any glitch. I think some server related issue with them. not with the luck of customer care person we choose. I have complained 4 times i got it solved just 1 hour after giving the last complaint. But they called me after a 24 hour later to confrim my issue solved or not. One rimweb member told their server is shfiting from ANdra to Mumbai thats the reason for this. any way now i am enjoying EVDO.
EVDO speeds can also be attributed to the modem that your phone is programmed with.. I decided to flash a Nexus modem on my Epic and found a speed boost of 10-15%
Sent from my SPH-D700 using Tapatalk 2
network has gone really bad, in open areas EVDO works great but indoors its slow like snail! 1x!
To all
Those who are facing issue related to evdo need to call customer care... its a problem from back end...
I was facing this issue since last 10-15 days.. when i shifted to another device and requested for evdo and i'm done...
Enjoying the same speed again
Sent from my DROID BIONIC via Reliance
i m facing the EVDO problem. the 3G sign appears and goes off in 3 secs.
i made complaint 4 times but still the problem persists.
pl guide me what should i say to CC to correct this problem..
Check whether any setting in the phone is doing so for example to save battery as evdo is a charge guzzler..
Reliance EVDO Speed at a same location:
I was getting more than 1.5 Mbps on my HTC EVO 3D
Now not getting more than 0.75 Mbps on Samsung S3
Fast Phone = slow internet :doh:
yeh kya ho gaya...
yeh kya ho gaya...
I'm getting 2.5mbps...
Would you like to trade with my Droid Bionic?
Lol
sent from my Droid Bionic via Reliance
Even the modem programmed on your device is responsible for Evdo speeds.. I flashed a Nexus modem on my Epic 4G and saw a surge of 15-20% in evdo speed from the same location..
Even the modem programmed on your device is responsible for Evdo speeds.. I flashed a Nexus modem on my Epic 4G and saw a surge of 15-20% in evdo speed from the same location.. Sent from my SPH-D700 using Tapatalk 2
Is it safe to do that on Sprint S3 ???
Check xda for installable modems corresponding to your device.. I guess each official firmware has a new modem so even an old modem could give you better coverage and speed..
yeh kya ho gaya...
Lol
Not again... :Sorprendido:
Seems like reliance data(1x & EVDO) services have stopped working since yesterday evening in North Delhi region. Don't know the reason why?
Anyone can confirm it?
Edited by abhi.r
working fine in south delhi
I've filed a complaint with customer care. They asked me for my handset model (I said Samsung Galaxy i500) and it's RSN number and said that my complaint will be resolved within 2 days.
Hope they could help.
I all have to agree the data as well as voice services are pretty messed in north regeion of Delhi.
I am constantly losing data from 3g to 1x at home.
Already lodged a complaint and getting updates that the issue is being looked at by technical deptt.
They have accepted that there is some problem
Sent from my Nexus 7 using Tapatalk 2
Neither 1X nor 3G symbols are shown on the Notification Bar.
Voice calls and SMS are working perfectly fine. Its only the Internet it cannot connect to.
I use my MDN to connect, (not RWorld username/pswd). Yesterday I filed a complaint to Reliance CC and they said that they will solve my problem in 2 days.
But credibility of Reliance CC has always been in doubt.
My phone (Epic 4G) is on People's Rom V 2.22, (Gingerbread 2.3.6)
PRL: 10005
Modem/Baseband: FC09
Is there a problem from back end or with my handset?
I tried making a Dialup connection on my Windows 7 laptop.
Dial: #777
Username: (My phone number)
Password: (Same as above)
The error message shown is: "Error 678: The remote computer did not respond. To make sure that the server can be reached. ping the remote computer"
Update: I went to different locations in Delhi. Also went to Gurgaon. But my net still didn't work (neither 1x nor EVDO).
So problem seems to be with my handset. Don't know what could have gone wrong! At one moment it was working fine, next moment it stopped working. Should i visit reliance web world? Can they solve my problem?
Edited by abhi.r
Sir...From past 2-3 weeks I am also facing the same issue on my HTC! I got the recharge of Rs.94/- (MH Circle) which gives 1 GB Data + 100 Daily SMSs per month for 6 Months. I haven't used the data much and just for WhatsApp and GMail. It worked fine in the beginning but I never saw '1x' and only '3G'. After that it stopped working. I lodged several complaints but all in vain. Any suggestions?
Another issue now I see is when I checked my settings thru QPST Service programming...
Under PPP Config tab UM > User ID: (my phone number)
AN > User ID: (my phone number) .... previously i remember it used to be my HDR Username/Password.
But now there is only my Phone number.
Gurus of Rimweb! Kindly please help if you can!
Edit: Flashed my old PPP dump file. Now settings seems fine. Now my HDR username is displayed under PPP config>AN tab. But my 1x/EVDO is still not working. :(
Edited by abhi.r
Just now I came back from Reliance Web World. The guy who was sitting on the desk recognized the handset.
he checked about my number in his system, and showed me that Intenrnet is Active on my number.
He ruled out any problem at reliance's end. he said that the problem is basically in the handset and not with Reliance's Network.
Got a phone from Reliance Technical dept.(Mumbai). First that person thought I had problem with GSM settings, when I told him that I am using Imported CDMA handset, then he said that there might be something wrong with the handset programming. :( Everything is okay at his end.
Settings>About Phone> Status> Mobile Network State ... "Disconnected" :(
I dont understand what could possibly be wrong in my handset settings. One moment it was working perfectly fine, other moment Internet is gone.
Now i officially need some help with it.
Edited by abhi.r
