vijaybavishi
Data cable and software
I just bought a rim prepaid service with a nokia phone. I cudnt get any data cable for the phone in trivandrum. does anyone have any knowledge of when this will be available here? rww guys say they dont have a clue and its only available in chennai now.
Also if anyone has used rconnect service in kerala, i wud like to know the speed of the service here?
thanks,
anoop
hi anoop
what price did the rww guys say for nokia r-connect cable? try searching in bazee. you will find cables a lot cheaper.
i am not sure if this topic should be in this forum, but if some other moderators find its not supposed to be in this forum then they will move it. there are 2 discussions which i found going on in the forum under r-connect. http://www.rimweb.com/forums/index.php?showforum=4
check the above link and i think that should explain your other doubts.
Click here for more details...
Click here for R-Connect Speed thread
just go to bazee.com. and search for reliance. you will find lots of stuff there
hi
i have searched baazee.com but didnt find any USB datacable for the FWT...
anywhere else can i get it?
thanks
u can contact Azhaga and find out if he can get u one... Check his post... his email id is mentioned there...
LG RD 2030 [COM] - Rs. 499                       Rs. 300
LG RD 2030 [uSB] - Rs.599                         Rs.480
LG LST 250E [COM] - Rs.499                       Rs.75
LG LSP 340 [COM] - Rs.499                         Rs.75
Samsung N191 [uSB] - Rs.499                     Rs.100
Samsung Colour Model [uSB] - Rs.499
Nokia 2280[uSB] - Rs.1200                          Rs.900
LG Colour [uSB] - Rs.799                            Rs.900
why is there a change in the rates?
i am not complaining, but......
the older pricing is for INDcables High quality products with warranty and bill , the next post will be the Cable pricing of baazee quality .
normally cables are not designed to that length.
Cables used for connecting pdas to mobile phones are commonly available
in lengths less than 50cm. It does not make much make sense to lug around
metres of cable to connect mobile devices, meant to be carried in the pocket.
it does not make much make sense to lug around metres of cable to connect mobile devices, meant to be carried in the pocket.
:'( nice one! But whts the current avl length of the cable?
well, if u want a really long/short cable u can make one yourself... the pinouts can be found out by searching at google.
i doubt if (very)cables work???????
Friends! Where can i get RD2030 data cables at Bangalore / Madras
Will it work with RD2130? I am having both the phones.
Which one is best? USB or serial cable, do they have any speed / performance diff? I heard that USB can charge the battery simultaneously.
Please help me to find one in Bangalore / Madras. :confuse:
HotGuy
Hotguy,
The Webworlkd guys told me that the cable is the same for 2030 and the 2130.
Its different for the 2230 though.
I have a 2230 and impossible to get the cable... till now.
Since have had bad experiences on Bazee, didn't bother to check out.
Tiger
Please help me to find one in Bangalore / Madras.  :quest:
HotGuy
Go for serial because there a no drivers for usb if u want r-connect(for 2130).
Please help me to find one in Bangalore / Madras.  :help:
HotGuy
Hi Emmy and Tiger!
Thanks for the sugestion. i will go for Serial cable. But where can get it in Bangalore / Madras? :rolleyes:
HotGuy
hi
i think there is a software which makes ur usb port act as serial. i dont remember the name, but it is a number. i had it with a samsung c100, but i dont have it now, coz i returned the cd along with the cable.
but i am sure you will be able to find it if u search on google.
someone who have usb please try it and put the result here so that those who have usb can benifit.
i think this is the software name "wd_pl-2303.zip"
this a link i am not sure if it is the same software, but it seems to work for c100
try it and tell me if it workedhttp://www.mobiles.unipro.ru/files/USB-Device-Driver.zip
HI
ANY ONE FRM HYDERABD NEED DATA CABLE FOR RELIANCE CONTACT ME @ 08703115023 YOSUFGUDA HYDERABAD .
as my phone wil connected net most of times u can SMS ME I WIL CALL BACK.
LGRD2030 serial cableIS AVAILABLE WITH ME (any no) for just rs 350
and smansung sch 191 usb for just 250.
NOKIA 2280 USB FOR 750.
NOKIA GSM ALL MODELS DATA CABLES FOR JUST 650
any one frm hyd can have these cabeles frm me .
my aim to provide good quality data cables @cheapest price for RIMWEB MEMBERS.
-praWIN
hmmm nokia cables in market which are not original cost 300 bucks for gsm and you say "just 650" :rolleyes:
Are you sure its the right data cable for Nokia 2280 that you saw for Rs.350 ? I have seen the normal price for Nokia 2280 in some shops and Baazee for around Rs.650
