HetalDP
Hetal's Aku 3.5.4.b, Sprint Radio 1.27, With Registry Tweaks
First flashing failed during upgrading of the extended rom. trying again.
Upgrade complete but after hard reset, the phone is hanging on the startup screen and the earlier image of the PPC6700 is not there, just static. will try once more.
Flashed it for the third time, but the same problem. Phone hangs up on the startup screen which is showing static.
Pls help Hetal.
Amit
dito... upgraded it twice myself... to no avail... hung at splashscreen... with static in place of the image file...
hey hetal,
i bought this handset from sadik and now using it with my postpaid connection. (old chat n play plan).
what i want to ask u is - when i click internet explorer, it automatically connects thru 'rel mobile world' after dialing #777.
is this connecting thru 'r world' or 'r connect'.
i m under old chat n play plan, in which i m not charged for network usage(10p/10kb thing). so is internet free for me? if its connecting thru rworld, then internet is free for me.. i just want to know one thing that is the default connection rworld?
please reply to this.. thanks!
yes default connection is r world.
to confirm, go to start settigs, connections, connections, and see which two you see,
it should be r world and my network connection.
also if you have not put in your userid and pass anywhere you are not likely to be using r connect.
I did not try this ROM and since you guys found problems i will wait till hetal fixes it.
yes some issue with 3.5.4.B which shall be resolved tomo morning
Hi Hetal thanks again...Have u fixed the problem in latest upgrade pl confirm so that everybody can start flashing it
thanks
he is on it even as we speak... once done it would be notified here... check back periodically !
@Kalpak
Removed the Following Items
Pocket RAR
Mobibook Reader
DictEditor
Windows Live Search (Who Search from this PPC)
UI Twaeker (To Complex to use)
HTC Zip (As already Resco Explorer is doing that)
and Saved 3.5 Mb Precious ROM Space
Edited by hetaldp
Hetal is it possible to extract QCN files from ROM kitchen? I want QCN, QCT, QCTUSB dll files and my be other files.
Yes we can Extract But any Specific Reason for that.
can someone guide how to use WiFi in airport..
i got the signal for Bsnl,tata ...
but how to use it..
kindly step by step ,please
3.5.4 B is up and running...
orange being the colour of the day !!!!
Edited by watersigndj
so should i download now?
yup no hassles
the procedure is
hard reset - flash rom - hard reset - boot - hard reset - boot - run ext rom - ur done
ext rom isnt clubbed in the rom?
it is clubbed... radio not there
thanks dheeraj
will do it and get back in the evening.
well done bro ....!
trying to upgrade now !
hope this solves my problem of heavy battery consumption !
Hey hetalbhai .. the upgrade was completed with no hassels ... but im not able to run some of the programs in PPC which i was able to before ... fring and verichat gave an error that "Its not a valid Pocket PC application" ... ne ideas ?
Well im sorry ... it just needed a soft reset ... and the ROM is awsome .!! hats off for Hetalbhai for providing such good stuff .!!
For FLashlite
Just Press and Hold 3rd Button on Left Side of Phone where e of Explorer is Embossed
And to Turn of FLashlite Just Press e Button Again
I have already Tried the Following Radio rom into my PPC
Verizon / Sprint / Reliance = Radio Ver 1.1
Telus = Radio ver 1.14
Alltel = Radio ver 1.15
now i have extracted the Latest Radio Version of Sprint from UTStarcomm December 2006 Unreleased Sprint Update
The Version is Sprint Radio 1.27
Just download the new rom and flash as per Guidence by the EXE
Hello there
i am Sprint user with ppc6700 i updated my rom using your update i am having a trouble connecting to my vision(internet)service and i don't quite understand what is the EPTS folder for and how to use the included files.thank you
Guest
