kshah
Discussion Topic For Palm Os Based Handsets, Softwares, Utilities, Comparision Etc
Hi Friend ,
I am just suggesting d way ..donno ..it might b wrong also ..dis is my personal exp wid 755 ....
In one of my bed room der is little n/w prob ......it go & cmes .........so i was keepin my treo der .......when i kept der ......i get hangs in 10 mins only after keepin der ....due n/w .....cme & go ............initially i didnt got d reasion behind getting hang .....
den after keepin in other room ...where der was full n/w was der ....it was not hangin der .........
So in ur case .....i think probably der is sme n/w issue cz ...whenever der is abrupt n/w change ...ie .cme & go Treo gets hang .......try exp iwd keepin in other area ..where .. no n/w issue it wont get . hang .........easliy ....
Above is my personal exp wid Treo it might apply for ur case or might not apply also ......just thought to share d exp as even i also get sme soltn for same .............
Thanks Chintan!
I am not sure i this is the issue. I suggest this because I have one more Treo 700p kept alongside, in the same room and that one works just fine.
Another thing that I noticed about the problem is that when I press the power button, the message "keyguard: Press center key..." does not get displayed and thats when the phone is radio goes off and come back on.----Same was the case with me also i was also not getting key guard message ...........if u get d soln for dis ...den do post friend ............
For now, I am reflashing the phone with the original Treo 700p ROM and hope for the best.
More ideas are welcome. :)
Can some one provide a solved uninstall manager?
here it is ....also try and install applications on memory card rather than phone memory
Uninstall_Manager324.zip
I use Destaller Lite. It can be downloaded from the link below.
Destaller Lite
Destaller Lite is a free tool. Destaller Pro is however paid.
Edited by concon
Thanks Chintan!
Tried everything. nothing helped.
Looking for fresh ideas....
Kshah/ Saadik : Have you ever faced such a situation?
detslller lite is also a good programme when it comes to uninstalling .....but i like a few additional features of uninstall mamager to b great like
soft reset tab
unistalling hidden application files
sandbox feature....so as to avoid system crashes
very strange problem though........have u installed anything on the phone.....also the network keeps on fluctuating that all of us have faced .....but the bars only keep on dancing all the time.....no serious issue though
Is there a solution?
Thanks Chintan!
i think u have to update 1.07 version of rom from palm update of sprint, that will make it more stable
Flash Player for Palm Treo:
There's a flash player for Palm OS which works quite nicely on my treo 755p. Seems to have been ported from the Flash Player for Sony Clie. Attached below.
flashInstaller.zip
Also attached are some SWF games and a HP scientific Calculator which work in this. palm_swf_games_etc.zip
All SWFs have to be copied to /PALM/Programs/MMFLASH (create the folder if its not there)
If flash player shows 'loading...' for more than a few seconds press menu button and select Mid or Low resolution instead of High resolution.
While most SWFs from the web will work, if its too CPU intensive then it'll take too long to load/run.
Does anyone know how to get this to render flash in opera mini or blazer ?
@amione
first off sony clies come with pre installled macro media 5 flash .....but i guess access power hasnt put in on treo.......using certain hacks u can install the macromedia flash files of sony clie on ur treo.....but its quite unstable....u can play swf files
for ur second problem.....firstly opera mini doesnt support flash...so it doesnt matter u have flash installed or not if u wanna use opera mini
secondly as far as blazr is concerned dude it is very backward in terms of a browser ......the development has been long stopped.....i dont think that u can successfully run flash on blazer as several signature files and database files rmissing which can got if palm decides to upgrade the os.....
i guess u will have to wait for palm nova.....or else google is ur best frend search for some alternative
Thanks mufaddal.
Have another query:
I have a holux keychain GPS which i used successfully with Nokia 6265 by connecting over Bluetooth (serial profile) and using Google Maps.
For Palm I found that there's a program called "where am i" which is able to connect over bluetooth to GPS and is then able to call Google Maps and show the current GPS position on it.
However, it has a known limitation that it calls up the old version of Google Maps from ROM (1.2) and not the updated one which we install (for eg 2.0.2)
Is there any way to overwrite the preinstalled ROM applications in Treo ? or any other way to get this app to call the new google maps.
Thanks for taking out so much time to reply to my queries and also the Docs to Go 11 solution.
@amione
first off even if u upgrade to version 1.07 the rom has version 1.1.2 of google maps .......now if u download google maps using blazer it installs verision 2.02 on your device
the prolem with version 2.02 is though it supports my locations feature but it has been deactivated by sprint thats coz sprint has a similar service and it wants its customers to use it in place of free google maps "my location" .....so thats y inspite of having google maps the my loaction feature doesnt work ....atleast not for me
now even if u have version 2.02 u can use unistall manager and unintall it ....and u get back to version 1.1.2,,,( thats coz in palm applications which r in rom are nevr removed instead the updates r installed over the previous ones thats y when u uninstal version 2.02 u get back to version 1.1.2.....)
so if u want to install version 1.2 do a google search and try to get a prc/pdb file of version 1.2 ( search in torrents) ...even i will try if i come across i will post it for u
well here it is ....just try
GoogleMaps.rar
Edited by mufaddal_km
Hey Amitabh, can you throw some more light on what you are trying to achieve. and how? I am thinking you have a GPS device that can communicate with Treo over BT. Then you are trying to use google maps to make Treo behave like a true GPS based maps device.
If so, please give more info about the GPS device and your success with making it work.
@harshal
what he is trying to do is connect his gps device over bluettoth with treo so hat he can pin point himself on google maps as my location feature has been disabled on sprint roms ........
@amione
though u r trying to get a connection with gps but it can never b used as a true gps device simply coz
1) u require data connection all the times for google maps as it downloads data ota
2) even if u locate ur self uisng gps still no navigation is available ......so if u r having nokia 6275 and if u have google maps on that with my loaction feature so better use it .....( there is a google navigator though for window mobile devices) ...
3) its difficult to get a third party navigation software for palm which wud work flawleesly here ......in fact i m not even braeking my head over gps thing in treo 755p
flash Player for Palm Treo:
There's a flash player for Palm OS which works quite nicely on my treo 755p..............
well since last few days i m trying to get you tube videos running on treo ......after reading thru certain forums a lot of people have been able to play you tube videos using third party support
after doin my search i found out this gr8 player called kinoma its supposed to the complete soln for playing online videos when it comes to treos....it features an ibuilt flash player and it also gives u the capability to go to you tube site and play videos on ur device.....
even core player supports you tube but i donno it is very buggy ......i tried so many times but it just fails after few secs it goes blank ....
i have tried kinoma player and i was able to play you tube videos fine infact the sharpness was better than on mogul .....but there is a major problem with kinoma ...it requires to pay fot their latest version and only their latest versions support you tube or any online video sharing .....though i have solns from different sources but all of them r not proper ......it wud just play once and all other times it gives an error asking me to get a valid copy ........
i m still lookin for a perfectly working soln .....but at present i think only kionma player can play you tube videos perfectly fine on treo ......
@Harshal / Mufaddal
GPS works with this treo as good as with the Nokia 6265.
In nokia i was using a Holux GPS device (purchased from ebay for 4K - holux 1000). This GPS is matchbox sized device with a bluetooth connection which transfers data to the phone and interfaces with google maps or mgmaps (mgmaps.com)
Initially, there were 2 problems with Treo:
1. I was unable to connect treo to holux which uses BT serial port profile.
2. Google Maps for Palm doesn't have any menu option for connecting to BT GPS device.
On googling i found that there is a software called WAI (where am i) - attached below or can be downloaded from
mytreo.net/downloads/where-am-i,1172.html or http://wfmh.org.pl/carlos/
whereami_1.9_for_google_maps_gps.zip
This app is able to connect Palm/Treo to holux or other GPS devices over bluetooth SPP and then it runs google maps and shows current position on the map in real time (as in nokia 6265).
In both Nokia 6265 as well as Treo 755p there is no turn by turn navigation etc. But once you can see the roads and your own position you can easily navigate.
The requirement of internet connection has never been a problem as after connecting to rconnect/rworld I use google maps extensively in map as well as satellite view (for quite extended durations w/o treo going into dormant mode and not waking up etc.)
* In case you don't have a GPS device & still want to try WAI out then you can select 'mimic gps' option and it will generate a random lat-long for current gps location. Then select 'show my location in googlemaps' and it will run googlemaps and show this position on googlemaps. Pl. note that many times random lat-longs will be over the ocean so you will have to zoom out 5-6 times otherwise all you'll see is blue background.
My only minor problem has been that WAI always runs the old googlemaps which comes preinstalled in the sprint ROM. As per WAI FAQ, it can only call the ROM version.
The my location feature in some phones I think is tower based and not accurate as it can only triangulate to 0.5-1 km accuracy while most GPS devices incl the holux i have even show on which side of the road i am (if you're zoomed in fully)
Hope that helps.
to cut it short it simply means that u r getting my location feature of google maps with "where am i "......pointing ur location on google maps using data connection. for maps and holux device for gps
i know u can do certain navigation by knowing ur location ....,,but one thing i dont like about google maps is it loads a lot of data over net ......it is too much to pay for to simply get elementary naigation( though a good option for people having unlimited netconnect)
i still prefer a navigation s/w with maps preloaded so that u dont have to shell out for navigation.......this is y i love my mogul and n95 i get all navigation and maps everythin without ever goin online ........the problem with treo755 is that there r very few navigation s/ws available and they have no coverage for india.....and as it is sprint has its own navigation services.......
i guess in this case treo800w is better with gps and windows mobile there r a lot of navigation s/ws available .....again lucky tata customers
@mufaddal:
Yes, that's true. Preloaded maps would be much better than googlemaps.
But this works ok, in the absence of other alternatives - have been trying to get a Mogul from Sadik for quite some time now but.... " Sadik has left the building " !
Sadik Bhai,
Pls give me some good software for call block and call filter for my Treo 755p.
I downloaded from the forum but it was trail version.
@mufaddal:
Call filter (solved) is avilable in the last but one page of the other treo thread..
go and get it..
[size="4"]A better Sync Solution for PC
[/size]
Supports the following CRM:
ACT! by Sage
versions 4 and higher
Premium, Real Estate and Financial editions
Google Calendar
GoldMine
Standard, Corporate, Premium and Enterprise edition
Lotus Notes
versions 4.6 and higher
Microsoft Outlook
versions 97 and higher
Business Contact Manager 2007
Novell GroupWise
versions 6.5 and higher
Palm Desktop
versions 2 and higher
support for Palm Desktop 6.2 coming soon
SalesJunction.com
Time & Chaos (more...)
versions 6 and higher
Time & Chaos !ntellect
Posted after 33 seconds:
Supported mobile devices:
BlackBerry handhelds
Windows Mobile handhelds
Palm OS handhelds
Apple iPhone (USB sync via iTunes)[liveurl][/liveurl]
http://www.companionlink.com/products/companionlink.html
cl_kg_9316.zip
this keygen contains a trojan horse. pls upload a virus free file.
A better option -
I'm on the STD version.
Download link:
http://www.synthesis.ch/dl_client.php?lang...PALM#dlds_CPDA1
(The .prc file installs fine directly on your phone over email or web.)
Here are my settings:
Server URL:
https://m.google.com:443/syncml
User:
[yourname]@gmail.com
Password:
[your gmail password]
Synchronize databases:
(Check Contacts, uncheck all others)
On the first "more..." screen:
Contacts: Slow (for the first time -- will automatically change to Normal for subsequent syncs)
Server Path: contacts
That should be it!
The lack of Calendar support over SyncML appears to be a limitation on Google's end, not a problem with the SyncML client. I'm using GooSync for now: http://www.goosync.com/
