joshm
okay ran the JT's JB Alpha for three days , its nice a smooth , really what you expect of JB :) :) and worh flashing
BUT if i tell you there is something more BUTTERY already available that too with every damn thing working ;) ?????
here is another surprise , for all of those who feel ICS has bad battery life or it lags and starts to act up like your Ex ;)
well , ( its true ) but I hereby present to you all with
Ultra solid , more buttery than JB ( i am not kidding ) ,
Teamhacksung's ICS Port for Fascinate (BUILD 15) [07/10/12]
I am impressed - Totally clean , mean looking cynogen mod 9 aka ICS port
PART 1 - If you are already on AOKP ics or any other MTD ROM
Here are the files needed [ STORE THEM ALL ON YOUR SD CARD ]
1.. BUILD 15 ROM - (MD5: 75d3b0bd145aff11653192ebd461126f)
http://goo.im/roms/s...eng.BUILD15.zip
2.. Latest GAPPS -
http://goo.im/gapps/...0429-signed.zip
3.. ICS DATA Fix ( required to get the 3G data running , which gets disabled while flashing any ICS ROM on imported I500 mobiles )
http://www.mediafire...srqv32venglftmq
4.. Exclusive Devil Kernel - Devil3_1.0.2b-ICS_fascinate_CFS_BLN_CMC_20120723
http://www.mediafire...e6hs3z3chsuoz2e
INSTALLATION :
1.. backup data , backup apps with whatever method you like
2.. Hit power button > select Reboot > Select Recovery > Make a nandroid
3.. Once your nandroid is completed > wipe DATA/factory reset > wipe cache partition > go to advanced > wipe dalvik cacahe
4.. Once done > Flash the ROM > if upon completion of ROM flash your phone itself restarts and goes back to recovery again > dont panic ;) > again wipe all three and flash the Rom again
5.. once Rom flash completes > flash the DEVIL kernel mentioned above > flash the gapps > once them are done> flash the data fix
PROFIT
PART 2 - If you are still in stone age ( ;) kiddin ) with Gingerbread, Froyo , Eclair , or CamaCola or Hamam ;P - then follow this procedure
Files needed
1...ODIN
http://www.mediafire...6ipsaf418ah8gr5
2..Atlas pit
http://www.mediafire...19fo7ftwgz8tgr8
3..EH03 Stock Gingerbread ROM for Fascinate
http://www.imnuts.or...3_GB_CM.tar.md5
OR
http://www.mediafire...g4afpb8u522oj2y
http://www.mediafire...r4fi9gl59j832yl
4..Clockwork Mod recovery fixed for CM9
http://www.mediafire...fl733m5cys3f6ea
INSTALLATION -
1 .. Make a nandroid backup of your current ROM ( better safe then sorry - just in case you messup anything )
If you dont know how to make a nandroid backup then ask around the option is there in all custom cwm recoveries
2 .. download all the files on your SD card mentioned in PART 1 of the totorial above
3.. turn off your phone > remove battery > attach the usb cable and put it in download mode ( press vol down and insert the usb cable which is already connected to your PC )
4.. Double click and Open ODIN ( your phone should show on a com port inside odin > click PDA > select the EH03 stock GB file that i have mentioed above
5.. Click Pit and select the atlas pit file mentioned above
6.. Hit start , the stock GB will be flashed > it will take ten minutes for the flash to finish, once completes , put the battery in
7.. Reboot phone > it will take another 10 or so minutes , once it boots shut it down
8.. remove battery > put phone in download mode again ( by holding vol down and inserting the data cable ) > and in PDA section flash the clockworkmod fixed for Cm9 file
9.. Once it completes > put the battery in > DONT restart phone > instaed push and hold volume UP and Volume Down and power button together and you will boot into a all new BLUE cwm recovery
11.. wipe DATA/factory reset > wipe cache partition > go to advanced > wipe dalvik cacahe
12.. Once done > Flash the Team hacksung ics build 15 mentioned in part 1 , ( which you have stored on ur SD card ) > if upon completion of ROM flash, your phone itself restarts and goes back to recovery again > dont panic ;) > again wipe all three and flash the Rom again
13.. once Rom flash completes > flash the DEVIL kernel mentioned above > flash the gapps ( as mentioned in part 1 ) > once them are done> flash the data fix
PROFIT again ;)
btw : You cant hold me or RIMWEB responsible, If upon following any of the above steps YOUR PHONE bricks and becomes an expensive paperweight, or ghosts start to haunt you or anything bad happening to you.
Hey the GOOIM links are not working.
Please give some mirror links.
Thanks.
Gimme some time I all upload the goo files for all on a different server
Sent from my SCH-I500 using Tapatalk 2
well i am using build 15 since more than 2 weeks now its smooth and work flawless the battery drain was higher than before
but i solved it by using the juice defender ultimate c****ed
any other tips for better battery performance welcome
joshm, you rock man the passion you have for trying out things and solving up many issues.
I am still on froyo 2.2.2 ED05
What to flash now and which ones for upgradations do share.
shall i go for your official GB ya ICS
Well how to get in the diag mode in the THS ICS rom?
AOSP roms dont have diag mode!
Sent from my Galaxy Nexus using Tapatalk 2
This method works in some Samsung models like Epic 4g, Epic 4G Touch, Galaxy Nexus and SIII >> http://forum.xda-dev...d.php?t=1626638
Theoretically it should work on Fascinate too. Try.
@joshm i have Samsung galaxy SCH-i500 Reliance and i have used the STOCK rom link of EH19 provided b you and installed successfully but after every reboot of the phone it is not saving the settings of the phone i.e installed application,CDMA settings. Help me out to resolve the issue
Dear Josh
I am. Not getting Facebook contacts after updating to ICS. Its not syncing properly even if its shows syncing in settings.
Tbh i dont know anything about how the reliance roms work on official reliance handset.
May be try a factory reset or data wipe
@jabir
Wipe cache wope dalvik
Then run the fix permissions option in recovery.
Should fix it
Mobile data not working after flashing to ICS from SCH-I500 reliance stock ROM EH19 if upgraded to GB VZW phone strucks at language selection any sugesstions how to enable data....
It works. I have tested it long work. :) we can do into diag from aosp, ics.
@amitroutray sorry of delayed i have tried your solution but i am unable to detect my phone in the DFS and CDMA work shop so installed Jelly bean/ICS every thing works fine i.e voice calls and messages but mobile data is not working
It is only working in STOCK ROM or you can follow Rajan ji's formula.
Can some one upload stable RELIANCE STOCK ROM for SCH-I500 as mobile data is not working on any of the other ROM of Verizon tried also ICS and Jelly Bean still no use and in EH19 Stock ROM Kies is not recognizing the phone it shows error message that "UNREGISTERED DEVICE"
Reinstall Samsung drivers on your PC first and see if it solves your issues first.
If not then Odin the eh19 again.
Sent from my Nexus 7 using Tapatalk 2
@grebel, I have the froyo stock rom ie ek10 which I personally use to go back to whenever something goes wrong. Please pm me your email address so that I can share it from my Google drive. This will restore your handset to stock Condition
@kkicdma
Hi kartik, I remember that you too had a reliance handset. how did you get the data working on Ics ? I've tried innumerable times to get it to work but have always failed to get data on any aosp aokp roms. I am able to flash only tw roms successfully (with data working)
I've tried all the data fix files from massaint and others too. I have tried apn backup restore too. I doesn't help on reliance handsets.
@Maverick75, I had PM you my mail ID and waiting for your reply thanks for the support..
@joshm done all the procedures what u have said still same issue
@Maverick75, Thanks now i am Stock ROM which u shared every thing is working fine thanks for the support
@joshm After installing the @Maverick75 provided stock ROM now Kies is detecting the phone
