HetalDP
Reliance Gsm Networks Features And Gprs Settings
104 posts in this topic
Rcom CC is the best for not solving your problem !!
They make you more :confuse: :confuse:
thanks for the info sir
Dear Hetal Bhai,
Any idea about how to get GPRS working on Blackberry 8830(Purch from Sadik Bhai, excellent handset) When i send message "All" to 55100, i get a message" your handset information not in database". any workaround? :signthankspin:
Just call customer care and tell them that u tried sending sms "All" to 55100, but u havent got the settings.. hence pls activate gprs on ur number, And tel them ur handset is Nokia E63, ( dont tel them u have BB 8830), and they will activate the gprs on ur number ... then in ur handset APN setting put rcomnet save exit and ur done...
There is Monthly Plan (auto renewal) Rs. 99/-(300MB)http://www.rcom.co.in/
Also you have to go into rworld on ur handset and chose ur plan to get it activated .. if rworld is not reponding properly on ur handset then again call CC and tell the that u have Nokia E63.. and get ur desired plan activated.
Hey Guys, Team,
Don't know if anyone can help. I ve been struggling since a while to configure the MMS on my Iphone.
I called RCom GSM, and they say the MMS is activated. So i entered the following settings
APN: rcommms
MMSC : http://10.239.221.47/MMS
Proxy Server Address : 010.239.221.005:8080
User Name = leave it blank
Pass word = leave it blank
I tried switching on and switching off the phone.. but still cannot send a simple picture, or even a short text by MMS..
Anyone can help ? how to do with this Iphone ? Did i miss something ?
Huge thanks to all of you for help !!
Hi Guys
Found the solution... In fact...Even if you never enter any MMS settings.. you need to do first.:
-Reset all network settings.
It will automatically restart the IPHONE, then add the settings.
And try.
If it doesnt' still work...Switch on and off again, and it should work.
Cheers
Cant't we connect internet on Laptop thru reliance gsm PREPAID ??? what will be the dialing no. in that and username and password needs to be blank !!!
Yes...you can using rcomnet APN... dialling number #777, username: your mobile number, password: your mobile number...
^^^ It is charged per minute(60p/min) and not based on data. right?
^^^Yup
hi
Can you pl help me set the Google supported Anaroid OS samsung galaxy with Reliance GPRS settings for post-paid connection??
even the customer care havent beeen able to help!
thanks a lot!!
cheeki
Is anyone able to run Opera mini with the rcomwap apn?
:previous: Yes, it should work and I have tried in the past
I have not been able to get Opera Mini 4.2 work with rcomwap, on my Moto. Works fine with rcomnet though. But now that tariffs for both are same, I guess it shouldn't matter.
Edited by raccoon
I have micromax Q5 mobile.I sent SMS ALL to 55100 for GPRS settings .When i am opening recevied SMS from 55100 giving error authentication failed.Can any one help me on this issue.
dear sir,
very very informative post.
thanks much
has anyone got email working on samsung corby yet with RGSM?
i did the sms with ALL
and reconfirmed all 3 manual settings but still i get server error when trying to connect
both to gmail & yahoo mail
kindly google search for corby imap settings for gmail
Hi Hetal
You seem to be the guru on Reliance, please help
I have got an iphone 4g and i was trying to set up the GPRS setting on it, i have tried various things like
1)Puttinthe cellular data settings
APN rcomnet
Username (blank)
Password (blank)
2) Internet Tethering
APN rcomnet
Username (mobile no)
password (mobile no)
3g access and data roaming switched off!
I dont know what am i doing wrong for as to access GPRS/ EDGE on my mobile. Upon calling customer care, they are asking me to update the phone from apple service centre, which i find is weird.
How to set the GPRS in my Samsung C3200 Handset.
I am using prepaid RGSM connection.
thanks in advance.
When did ou purchased RGSM Prepaid cards
Hi Hetal
i just activate gsm postpaid Connection here in Mumbai
then i activate the M99 plan for gprs 2.5 gb free
i got seeting for rcomwap but i cannot access some software for stock market they have steaming quote.
ans CC at 198 say we have only this plan so how can i work that software
Please Help
It worked beautifully for my 02 XDA IIS handset, with GSM post paid facility on it, but I am struggling to get this working on my Nokia X6, any advice ?
  1. Support Enhanced EDGE with Fiber backbone which can give Pratically 220 kbps speed to Latest EDGE Handsets
  2. Only GSM Network which Support Over The Air (OTA) time Sync (Automatically Sync Phone clock to Network the way it happens in CDMA)
  3. SIM Toolkit Version 2.0 Support, All SIM Card is power which STK Version 2.0 which can make Automated Configuration Request, OTA PRL and Commands Updates. OTA SIM Contact Updates and Programming, Handset Initiated SMS etc.
  4. R-World (The Same R-World) intranet WAP Site is extended to GSM Network users also. If your have GPRS / WAP Settings Enable you can Access R-World and manage so many things the way we did it in CDMA Service. You can reach R-World by Visiting http://wap.rworld.co.in on your Handsets
  5. Assisted GPS, All Tower of GSM / CDMA is suported with Assisted GPS, i am not sure that Reliance extend this Feature to GSM Handsets
  6. Frequency Beaming / Shapping. To Better cover and reused Spectrum they have got latest Towers from Trenqx from Canada which Shape / Beam Frenacy to only Targeted Area, so Same 4.4 Mhz can be Devided in 4 Slice and 4/1 Network can be made.
  7. Call Waiting / Call Diverting Feature can be Activated using The GSM OTA commands or By Dialing *62*93xxxxxxxx#
  8. MCA / Missed Call alerts is allowed but dont know about Status
  9. Caller Tunes is working fine we can Activate using SMS, Calls to 51234, R-World or from rcom.co.in Website using Mobile Number and Password.
  10. RCom.co.in site can be use to take login Create A/c for Mobile and pay bills and view Unbiled Usage (Same as CDMA)
Important Numbers
Voice Numbers
Recharge = *368
Balance INquirey = *367
Custoimer Care = *333 or 022-30333333 or Tall Free = 18001003333 Admin menu / Common Access Number = *369
Language Menu = *364
USSD Menu = *123#
Caller Tunes = 51234567
RWorld Menu = 51234
Call Divert = *62*93xxxxxxxx#
USSD Codes
Recharge = *368 (14 Digit Recharge Voucher) #
Balance Inquiry = *367#
SMS Codes
Balance Inquiry = Type BAL and send to 53670
To Subscribed Caller Tunes = Send sms SUBCT to 51234
To Unsubscribed Caller Tunes = Send sms UNSUBCT to 51234
Dont Call Registry Activation = sms START DND send to 1909
EMail
Customer Care = gsmCustomerCare@RelianceADA.com
Reliance GSM GPRS Settings
__________________________________________
Reliance GSM WAP Setting
( Required to run RWorld )
( Postpaid and Prepaid )
APN: rcomwap
Login Request Required : off
Authentication : PAP
Data Compression : off
Header Compression : off
Settings Name: Mobile World
Home Page / WAP Page: http://wap.rworld.co.in
Proxy: Yes
Port : 8080
Full Address in case of Windows Phone : 010.239.221.005:8080
Reliance GSM MMS Setting
( Required to to Send and Receive MMS)
APN: rcommms
Settings Name: Reliance MMS
Proxy: Yes
Port : 8080
MMS Server Settings
Server URL: http://10.239.221.47/mms/
Ip Address: 10.239.221.5
Apn: rcommms
Reliance GSM Net
( Required for Emails and Actual GPRS )
( Postpaid Only )
( You will require to contact GPRS Technical Department to Activate Net Plan / I got it but its a Hidden Plan )
( PC Tethering Allowed )
( Visit http://www.rcom.co.i.../prosumers.html for More info )
( on Latest Prepaid and post paid this can be sued with RWorld Browsing Plan but i am not Sure )
APN: rcomnet
Settings Name: Reliance Net
Home Page / WAP Page: http://google.com
Proxy: no
Proxy Server Address : leave it blank
Port : leave it blank
Full Address in case of Windows Phone : leave it blank
Reliance GSM NetConnect
( Postpaid Only )
( Pay per Minute Plan )
APN: rconnect
Login Request Required : ON
Settings Name: Reliance NetConnect
Proxy: no
User Name = 9021310001 ( Your 10 Digit MDN )
Pass word = 9021310001 ( Your 10 Digit MDN )
iPhone will not Support WAP Setting because of non Support of Proxy based Internet, iPhone will require Pure Reliance GPRS Setting. and also iPhone will not support RWorld because of non Proxy Support.
Google G1 Support only one APN Settings means either it will support RWorld or MMS or Internet
(Now Google based Android Support Multiple APN just set type = default (for internet) and type = mms (for MMS))
I tried the below settings for both "internet settings" and "wap" in my Nokia X6, its still not working, although Reliance guys did tell me it will take 24 hours more for GPRS to be activated on my number.
Weird thing though is, I have another GSM number, and I did not have to ask them to activate GPRS but net worked just fine on my 02 XDA IIS
If someboidy have Activate Rs. 303 Unlimited GPRS and have GPRS APN Settings Please post here, i want to Test Internet Speed on my phone
Here Is Settings
RLTNET:
Connection Name:RTLNET
Data Bearer:Packet Data
Access Point:SMARTNET
Username:blank
Password:blank
Authentication:Normal
Homepage:Http://www.google.com
Network Type:IPv4
Phone IP:Automatic
Name Servers:Automatic
Proxy Server Address:blank
Proxy Port Number:blank
RLTWAP:
Connection Name:RTLWAP
Access Point:SMARTWAP
Username:blank
Password:blank
Homepage:Http://wap.R-world.co.in/gsm/index.xhtml
Network Type:IPv4
Phone IP:Automatic
Proxy Server Address:10.239.88.2
Proxy Port Number:8080
MMS:
Account Name:RTLMMS
Access Point Name:MMS
Prompt Password:No
Password:Blank
Homepage:http://10.114.0.5/mms/
Authentcation:Normal
Network Type:Ipv4
Phone IP:Automatic
Primary Name Server:Automatic
Second Name Server:Automatic
Porxy Port Address:8080
Hello,
I am able to connect Reliance GSM through rcomwap settings on the default browser in my mobile. When i try to connect internet using my PC, it connects but any webpage doesn't open at all. I can also not use operamini browser in my mobile using rcomwap.
Any idea to solve this?
Thank you,
Harsh
Have the settings changed?
I am trying to use rcomnet to surf the net through mobile phone. I have Reliance GSM postpaid, and my handset is LG P500(Android 2.2)
I sent sms M99 to 51234 and got back the message that my data plan will be activated shortly.
